CJ keeps eating my distributor gear??? - JeepForum.com
post #1 of 15 Old 07-08-2011, 09:05 PM Thread Starter
drerict
1983 CJ7
83 CJ with a 304 out of late 70s era wagoneer,
Here is the skinny:
Had the motor rebuilt with a stock cam 1000ish miles ago with complete balance etc.
I got about 1000 miles on the first distributor gear, one cold morning, jumped into the jeep and got about a block from the house and a big back fire, then died on the road, would not start after that.
Pulled it home, pulled the distributor, the teeth were almost gone on most the the gear, and some places completely gone.
Took the distributor back the machine shop, no warranty on used gears. What? After paying about $3500 for this motor, they used old parts?
Now they looked at the distributor and said there was too much play in the distributor shaft, and it was riding up and down on the cam gear under acceleration wearing the gear down. So I ordered a gear through them (MSD) and had them install it on the distributor, and put in shims so there was appropriate play.
Got it back a week later, installed it, I could not get it timed, before that gear was shot also.
I took the distributor out, and realized it did not spin freely like it did before the machine shop put the shims in. I then realized that getting a re-built distributor from NAPA was cheaper than the gear through the machine shop.
I then put in the new distributor, I got about 20 miles and again, back fire, and the gear is gone.
Now I realized I have a bigger problem, the cam gear is probably shot. I ordered a new set of "matching" MSD cam and distributor gear.
I took the front of the motor apart to install the cam gear, I just thought I would check the oil pump. I found that one of the gears was installed upside down (the dots were installed on opposite sides). I re-installed the oil pump gears. Installed new cam gear, new distributor gear with the the rebuilt distributor. Changed oil, new anti-freeze. Now I got about 60 Miles out of it.
Now today the jeep started backfiring again and quit. I was able to get home coasting, but now I am baffled.
Please give me some ideas to diagnose what is causing the distributor gear to take a crap so fast.
Thanks,
Eric
Firefighters Jeep Club
drerict is offline
post #2 of 15 Old 07-08-2011, 09:55 PM
JeepHammer
Running On Empty...
1973 CJ5
First thought off the top of my head is...
1. Is the oil pump binding?
If the oil pump is too tight, it will kill distributor gears instead of camshaft gears most times.
2. Is the camshaft walking?
If the camshaft walks forwards and backwards, it will usually eat the distributor gear before it chews up the camshaft gear.
3. Did anyone clear the overcast out of the upper sprocket for the timing set?
If you didn't, then the gears and fuel pump eccentric, along with the timing set, aren't getting any oil.
Oil passes between upper sprocket and camshaft nose on it's way out to the accessory drives, and most upper sprockets have overcast in the oil passage groove.
4. Are the oil passage holes lined up on the accessories?
Since the oil has to pass out to the accessories, if you don't make SURE everyhting is lined up, you won't get oil to the drives.
5. Did you check the camshaft gear for an oil hole?
Some gears don't have oiling holes, or don't have them in the 'Correct' place for your engine type.
AMC moved the oil hole about 90 degrees between '69 production engines and '70 production engines, so you have to check to make sure the hole is there and in the correct location.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 15 Old 07-09-2011, 07:24 AM
mopar408
1974 CJ5
do the oiling "mod" to the timing cover.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #4 of 15 Old 07-09-2011, 07:29 AM
MoC
Is the cam gear installed backwards?
MoC is offline
post #5 of 15 Old 07-09-2011, 01:26 PM
COBRA5LADDICT
check the for flashing as jeephammer said that is the #1 cause. if you can remove the fuel pump and prime the oil system with a drill. you should be able to see the cam gear from the pump hole and it should be dripping oil while you are priming the system.
COBRA5LADDICT is offline
post #6 of 15 Old 07-09-2011, 01:57 PM Thread Starter
drerict
1983 CJ7
How do I know if the oil pump is binding? I used a screw driver on the end of my drill to prime the system after I put the front back together. It seemed to spin freely. I pulled the passenger side valve cover to be sure that the pump was working.
How do I determine camshaft walking?
I am not sure since the motor was rebuilt at the machine shop. I do know that when priming the motor, I get spash on the cam gear (visually saw the oil splashing on the gear).
Again thanks for your help. I am glad you are posting, it makes me feel better. I am sure I have spent more time reading your posts than acutally driving the jeep in the 7 years I have had it.
drerict is offline
post #7 of 15 Old 07-09-2011, 01:58 PM Thread Starter
drerict
1983 CJ7
Can you explain this more? What are the benifits and potential side effects of this?
drerict is offline
post #8 of 15 Old 07-09-2011, 02:17 PM
mopar408
1974 CJ5
the "oiling mod" takes oil pressure directly off the pump at the outlet for the oil pressure sending unit thru a line and to an "orifice" installed in a spot on the timing cover that is aimed directly at fuel pump eccentric/distributor drive and driven gears, thus feeding them as well as timing chain and gears with a pressure -fed spray of oil and not just a drip (hopefully) coming thru the front cam bearing.
I haven't figured pic posting here but have a good Picasa file and details if you/anyone is interested. Even if yours (maybe) works, can you have too much lubrication? Not!
2 hrs, 20 bucks, best thing I ever did to mine for peace of mind.
mopar408 is offline
post #9 of 15 Old 07-09-2011, 06:40 PM Thread Starter
drerict
1983 CJ7
Mopar408, if you can post the link, that would be great, or your picasa account name I can search for it. Any help on oiling would be great.
drerict is offline
post #10 of 15 Old 07-09-2011, 07:29 PM
mopar408
1974 CJ5
send me an email addy and I'll send you the info and a buncha pics. I've done it for several here already.
John Smith
flhbagger@gmail.com
mopar408 is offline
post #11 of 15 Old 07-09-2011, 10:21 PM
85LaredoCJ7
So...do you lose your oil pressure gauge with this mod?
85LaredoCJ7 is offline
post #12 of 15 Old 07-09-2011, 10:50 PM
Rollbar
1984 CJ8
Posting a pic, I just do it manually.
[img] then the http address or address where pics are stored,
then [/img]
So at the beginning you have [img] and at the end you have [/img] works on 90% of the forums on the web.
There is also the yellow square box at the top w/a mountain in it=click
<----Click
<---- Click
Rollbar is offline
post #13 of 15 Old 07-10-2011, 06:29 AM
mopar408
1974 CJ5
Absolutely NOT. You come off the stock AMC pressure fitting on the side w a "tee" that points up.
O/P sending unit goes in the side and fitting for the mod goes into the top. I also like to change to the long skinny Wix/NAPA filter instead of the stock short fat one. Makes a lot more room in an already crowded area anyway.
mopar408 is offline
post #14 of 15 Old 07-10-2011, 11:40 AM
85LaredoCJ7
Did you notice a change in the o/p on the gauge? Did you drill/tap your timing cover in place?
post #15 of 15 Old 07-10-2011, 12:40 PM
mopar408
1974 CJ5
It didn't drop 1 POUND!!!
I was wondering about that myself but decided if it did drop appreciably all I had to do was put a pipe plug in the t/c and 1 in the tee and I was back to stock. I can only conclude that the orifice hole is so small as to not be noticed.
Kicked my own @$$ for not doing it while building my Moder but after I figured the trick, it's not a problem.
You hear stuff like grease on the bit, etc but here's the trick: Take a MALE air hose fitting like goes into your impact wrench, remove the PCV and put the THREADED end into the grommet. Remove the oil filler cap and regulate your air pressure down to 10-15 #. Chuck the hose to the fitting and you'll hear air coming out the filler tube. If you lightly place your palm over the top of the tube you can "regulate" a small amount of pressure in the engine. When you drill thru the t/c and also as you run the tap thru, the chips/shavings blow OUT (safety glasses here, they BLOW out). Clean as can be.
I've already emailed details and some pics out twice this a.m. Anyone who is interested, pm me an email addy.
mopar408 is offline
Chewing Up Distributor Gear On New Distributor TsCJ779 Jeep CJ Forum 9 04-05-2011 06:04 AM
No oil on Distributor Gear? Jeeptherapy Jeep CJ Forum 8 09-11-2008 09:16 PM
distributor gear Andy5150 Jeep CJ Forum 51 01-29-2008 09:31 PM
304 eating timing gear c17load83 Jeep CJ Forum 12 10-19-2007 03:52 PM
distributor gear kevbo Jeep CJ Forum 11 09-14-2007 10:09 PM
