CJ Jeep Starting Problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ Jeep Starting Problems
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 04-26-2004, 10:26 AM   #1
cj5jep
I own a 1979 CJ 5 jeep with a 258 and manual trans. I let the jeep sit for two years. When I went ot start the jeep the starter would not disengage. I had the starter rebuilt andreplaced the battery. Still same problem. What can I do to fix this thanks?
cj5jep is offline   Reply With Quote
Unread 04-26-2004, 10:35 AM   #2
Scrambler82
Scrambler82's Avatar
1982 CJ8
I'm guessing here but the next electrical thing in line would be the solenoid.
Try banging it and attempt to start teh vehicle again.
After that check the ground of teh solenoid, the mounting bracket, if it doesn't have a good ground it will not work right.
After tht I would start looking for wiring that is shorted together.
Later,
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Unread 04-26-2004, 11:06 AM   #3
skip3
It sounds like the solenoid to me too. You can short it out of the circuit by using jumper cables between the battery (positive) and the starter side of the solenoid to verify. You can also short the battery post and starter post of the relay (solenoid) to do the same thing.
I recently revived my CJ7, and had to wire brush most of the electrical connections. From reading this forum, bad terminal connections seem to be a common Jeep problem.
Skip
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell
skip3 is offline   Reply With Quote
Unread 04-26-2004, 12:43 PM   #4
Geer_hed
Just for clarity's sake, I'm assuming you mean that the starter motor won't stop cranking, not necessarily that the starter motor drive gear won't retract. If that's right then your starter solenoid is highly suspect. Take a test lamp and look for signal from the IGn Switch on the solenoid. It should die when the key is not in the start position. If there's no signal from the IGN SWT and the starter is still cranking, then your solenoid is bad.
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote
Unread 04-26-2004, 04:53 PM   #5
J33P1N
i just re-ran my hot wire that goes into the fuse panel. all the connections were pretty crappy, got the wire brush and cleaned them all out. put it all back together and starts like a champ. all it took was a few hours and a couple beers.
J33P1N is offline   Reply With Quote
Unread 04-27-2004, 11:16 AM   #6
Scrambler82
1982 CJ8
Glad to hear you are OK, for now.
You should put that same effort into the ground system; grounds always go bad on Jeeps.
You see what the other connections looked like, well the grounds are probably more corroded than that.
If you do re-do the grounds, use a conductive paste on the connections.
Later,
Scrambler82
