CJ Jack? - JeepForum.com
post #1 of 7 Old 10-23-2003, 06:02 AM Thread Starter
TrappG
TrappG's Avatar
CJ Jack?
My CJ needs a jack. (I'm assuming it origanally had one but it is nowhere to be found) Where did it mount and what recommendations do you guys have for aftermarket jacks? Are there jack points on the vehicle?
'78 CJ7 - 304 - Hooker Headers/Sidepipes
TH400/QuadraTrac, B&M shifter (sold spring '04)
'04 Sahara - I6, 5spd bone-stock...
TrappG is offline
post #2 of 7 Old 10-23-2003, 06:43 AM
PCB CJ7
PCB CJ7's Avatar
I found a convenient location to mount the HiLift here...
1983 CJ-7 Khacki/Spice, Hardtop/Softop, 258 M4, Hurst Billet Plus Shifter, Currie Twin Stick TC Shifter, 4.56s, 5.5" Pro Comp Suspension Lift, Conn Ferr Trusses/Skids Front&Rear,Currie Steering Box Stabilizer,Skyjacker Transfer Case Drop, Moser 1 Pc, 16-35-15 Swamper Boggers on 15x12 Stonecrushers, Acres of Stainless, and More lights than a DC9...:D
Stablemates:
02 WS6 T/A #3720, '00 SS Camaro #7485. '02 Z28 #5520-
PCB CJ7 is offline
post #3 of 7 Old 10-23-2003, 06:49 AM
wm69
The original jack was a crappy scissor jack like the one that's on my honda accord. There's a mount on the inner passenger fenderwell where they mounted them. Don't get one! I had a blowout one day and couldn't get the factory jack to even start going up. You have to take the thing off, hose it with penetrating oil, and put it in a vise to get it to go up (and I did this about 2 months before the flat) It also has to go waaaay up before your tires come of the ground. That inner fenderwell just has too much mud/ water go in there and it gums a scissor jack all up. My suggetion is to get a high lift with either a bumper or spare tire rack mount. If you are on the street most of the time, get an old screw jack from an early 80's GMC or chevy pickup, or a hydralic cylinder shaped jack. Thats' what I have in my jeep now (the GM jack) and i just pop it under the spring perch and go. If you have a high lift (to be added to my tire rack soon), be careful with it. I'm gonna get the little hooks that hang off the high lift and hook them on my frame mounted D rings I have on all 4 corners (if I get a flat off pavement and can't get the screw jack under the jeep).
wm69 is offline
post #4 of 7 Old 10-23-2003, 08:24 AM
fuzz401
1978 CJ7
a 78 cj it was located under the driver seat at the rocker pannel in a black bag with a snap and the handle was in there with it to
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #5 of 7 Old 10-23-2003, 10:30 AM Thread Starter
TrappG
TrappG's Avatar
Come to think of it, Fuzz, I have seen the bracket there it must have been mounted to... Thanks.
TrappG is offline
post #6 of 7 Old 10-23-2003, 06:14 PM
fuzz401
1978 CJ7
yes a u shaped bracket with a cloth like strap went through the slots in the bracket and the bag set inside the bracket
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #7 of 7 Old 10-24-2003, 07:04 AM
4wheeler4CJ
4wheeler4CJ's Avatar
I have a stock CJ jack, and it's not the scissor type. It is like a regular bottle jack but you crank it up. I have it listed in my post in the For Sale section for $40 including shipping. Has the long rods that you use to crank it too, it's all complete and not rusty.
4wheeler4CJ is offline
Jack Stand omanalansanjr Jeep CJ Forum 2 01-07-2007 06:21 PM
Tire Jack ClarkGriswold Jeep CJ Forum 2 10-20-2006 08:55 PM
Bottle Jack NMPhi767 Jeep CJ Forum 11 01-06-2006 02:24 PM
OEM Jack for '95 XJ b_hailey Jeep CJ Forum 2 02-26-2005 01:52 PM
Original Jack? bbop Jeep CJ Forum 6 03-14-2003 03:00 PM
