CJ Hardtop Lift Gates - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ Hardtop Lift Gates
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 07-31-2010, 03:42 PM   #1
GuacaTex
1981 CJ7
So what's the latest poop on replacement lift gates for factory CJ hardtops?
I'd love to hear about successful lift gate repairs/replacements.
The gate on my '81 CJ is so leaky that now my rear floor pan is rusting out. I'd try to patch the holes in the lower corners, but I'm afraid the whole thing will crumble when I remove the glass.
Original gates were steel. Steel reproductions are not available anymore. Fiberglas repros are available, but the price on the 'glas repos have skyrocketed. By the time you consider the addtional cost of seals, glass install, & paint - you can buy a whole new replacement soft top and have some change left over. I hate to junk the rest of the hardtop; it's in otherwise great condition.
What years are interchangable?
Anyone had any luck fabricating a replacment lift gate from acrylic (plexiglass)? I suspect it wouldn't be strong enough to handle the hinge loads.
GuacaTex is offline   Reply With Quote
Unread 07-31-2010, 03:45 PM   #2
DucST4
DucST4's Avatar
I have to add to this, my hard is pretty good, but the shocks are about dead. Anyone know where I can get a new pair?
DucST4 is offline   Reply With Quote
Unread 07-31-2010, 08:29 PM   #3
Shasta69
1978 CJ7
guess various auto parts stores have a universal lift strut kit with universal mounting hardware.
as far as lift gate, try looking for a hard top for sale. buy it, get what you need, then flip the rest.
much luck!
Shasta69 is offline   Reply With Quote
Unread 08-01-2010, 06:28 AM   #4
danheit
1979 CJ7
I'm in a similar boat. My top is great, but the rear liftgate is thrashed. I have been wanting to look into the replacement glass from an 87-89 YJ glass. I believe it may fit, and it still has the bottom part with the T-handle in it. I just need to get a hold of one to test fit. I just hate to spend hundreds of dollars to test it and find it doesn't fit. I think it would also be a good replacement in that it doesn't have the big metal surround, offering a bit of better visibility out the rear glass.
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7 Blue Jeep
danheit is offline   Reply With Quote
Unread 08-01-2010, 09:59 AM   #5
Full Tank
1980 CJ5
A couple years ago a guy had an NOS CJ7 liftgate on ebay. In his listing he claimed that the liftgate was also correct for the newer Jeepsters. I have no idea if that is a fact or not but it just may be worth checking into. They sure look similar.
Check the links...
http://cosprings.craigslist.org/pts/1861756977.html
JEEPSTER COMMANDO OBO
1969 Jeep Jeepster Commando
FT
1980 CJ5 39k
Dana 30--AMC20--D300--T176--258
Dana 30--AMC20--D300--T5--2.5L
Full Tank is offline   Reply With Quote
Unread 08-01-2010, 01:31 PM   #6
danheit
1979 CJ7
Nope, looks like the angle from top to bottom is too steep. The liftgate on the CJ is a little more squared off than that.
Unread 03-07-2011, 08:09 PM   #7
GuacaTex
1981 CJ7
J C Whitney now has a fiberglass lift gate in their catalog with price about 1/2 of what others have. Brand is "TopLine". JCW also says no drilling required.
This will probably be my next order. I need to get the jeep weather tight so the rear floor quits rusting!
Unread 08-23-2011, 10:26 AM   #8
esearscj7
1983 CJ7
Wow, not a bad price. $230 I'll be getting one of these too.
http://www.jcwhitney.com/fiberglass-...d=d1168y1983j4
esearscj7 is offline   Reply With Quote
Unread 08-23-2011, 12:13 PM   #9
Renegade82
Renegade82's Avatar
1982 CJ7
A piece of advice. Don't use the factory metal liftgate shocks on a fiberglass replacement. They are too strong and will tear the embedded bushings right out of the fiberglass. Big weight difference.
Renegade82 is offline   Reply With Quote
Unread 08-23-2011, 12:48 PM   #10
sanddrag
I don't believe that for a second. I just finished stripping down my steel liftgate and most of the weight is the glass. The metal itself is quite thin and lightweight.
sanddrag is offline   Reply With Quote
Unread 08-23-2011, 01:17 PM   #11
lucdog
lucdog's Avatar
1980 CJ5
I'll save you some time, Dan. YJ glass is 45.375" CJ 44.250", this is at the middle. The YJ glass also has less angle on the sides. Height is about the same.
Bill
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is online now   Reply With Quote
Unread 08-23-2011, 01:30 PM   #12
Renegade82
Renegade82's Avatar
1982 CJ7
Been there done that. It's not just the weight, it's the connection too. Suit yourself. You've been warned!
Unread 08-23-2011, 08:30 PM   #13
sanddrag
I'm in the process of refurbishing a steel lift gate, and I didn't really need to remove any hardware, but to paint it I figured I would. Big mistake. Nearly every bolt broke or stripped. After finally getting the hinges off, I now see that the backer plate that the screws thread into is all rusted and bendy. Looks like I'll be cutting it open for a repair.
Unread 08-23-2011, 10:36 PM   #14
WoodyHD
1983 CJ7
Don't have a picture on hand, but I blasted my lift gate and painted last winter along with a lot of bondo and paint on the hardtop. Was in great condition to begin with though. Brand new lift gate seal and it still leaks like a sieve. Anyways good luck.
WoodyHD is offline   Reply With Quote
Unread 08-24-2011, 06:33 AM   #15
twoleos617
here's one in the classifieds
http://www.jeepforum.com/forum/f129/...glass-1252009/
Torque is the measure that gets the cap off your beer.
Mike D.
twoleos617 is offline   Reply With Quote
