cj gas tank removal - JeepForum.com
post #1 of 13 Old 07-04-2008, 02:04 PM Thread Starter
sail78385
cj gas tank removal
just want to know if the gas tank is held in place only by the skid plate.
sail78385 is offline
post #2 of 13 Old 07-04-2008, 04:48 PM
kstopp
1993 XJ Cherokee
On my 20 gallon factory tank it was just held in place by the skid plate, I believe the 15 gallon is the same way. The tank is strapped to the skidpan and the skid pan is taken off the frame from a row of bolts along the rearcrossmember and another few across the next frame rail towards the front.
kstopp is offline
post #3 of 13 Old 07-04-2008, 04:57 PM
SuB8HaVeN
Yes, the skid plate is the only thing holding it on there. There's a steel strap on top of it also, but this comes loose when you remove all the bolts.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #4 of 13 Old 07-04-2008, 05:06 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Don't forget to remove gas tank filler hoses, vent lines, sending unit wires...etc.
Also, a full tank of gas is heavy.. might want to ensure it's empty or close to it.
BESRK is offline
post #5 of 13 Old 07-04-2008, 05:54 PM
SuB8HaVeN
I just used a jack underneath the tank to lower it slowly, and then supported it with cinder blocks.
post #6 of 13 Old 07-04-2008, 11:08 PM Thread Starter
sail78385
yeah the only reason Im doing this is cause my sending unit wire came loose and I have to put it back on. What a mess.
post #7 of 13 Old 07-04-2008, 11:29 PM
Floridazed
Floridazed's Avatar
1980 CJ7
fun. The tank is easier to work with if empty. Dry to run the gas an do the job on empty. Or siphon it. Either way, at 8lbs a gallon, and on your back, its a bear.
Andy
_______________
1980 CJ-7 : 151GM : Stock : In process of restoration (always constant, and something to do.)
Floridazed is offline
post #8 of 13 Old 07-05-2008, 02:35 PM
Wolf359
WOLF359
Wolf359's Avatar
Good info... I have a fuel pickup problem at a 1/4 tank. I've been procrastinating thinking the fuel tank was a ***** to yank out. Plus I need to install new body bushing back there.
Wolf359 is offline
post #9 of 13 Old 07-05-2008, 03:31 PM
peejcj8
I feel your pain, mine just sprung a leak. 2 days to remove and replace it.
peejcj8 is offline
post #10 of 13 Old 05-10-2013, 11:21 AM
CJ7ROB
Do you guys know if its possible to remove just the top strap on a poly tank without dropping the skid and tank? I know how to drop the tank, I just want to remove the strap only if that's possible, in order to paint it. Thanks
CJ7ROB is offline
post #11 of 13 Old 05-10-2013, 11:36 AM
nosheep
1983 CJ7
to the OP:I just played with mine, I have the 20 gallon factory tank and it take 4 bolts at the back and 3 towards the front to lower it. My bet is if you put a jack under it lower it a few inches you will be able to reattach your sender wire without having to mess with taking off the filler and vent hose. If you do end up having to deal with the hoses save yourself the headache and take off the 3 screws that hold on the filler cap assembly and disconnect the hoses there. As with any cj I applied plenty of penetrating oil to all the bolts/screw first.
nosheep is offline
post #12 of 13 Old 05-10-2013, 11:43 AM
CJ7ROB
Ok like I said, I know how to take the tank out, I just want to remove the strap alone if that's possible. Keep in mind tub is off too. Or is there no way to remove the strap without dropping the kid?
CJ7ROB is offline
post #13 of 13 Old 05-10-2013, 01:28 PM
nosheep
1983 CJ7
^ my Strap was bolted in and yes you could have probably got it off without lowering the tank very much. But I am not sure if all tanks are like mine it kinda looked rigged.
nosheep is offline
Fuel Tank Removal Help? bucs1fan Jeep CJ Forum 1 11-03-2009 10:26 AM
gas tank skid-plate removal davegt Jeep CJ Forum 6 08-12-2009 06:12 PM
Gas tank removal CJ7 dongogolf Jeep CJ Forum 2 11-09-2007 09:12 AM
Fuel Tank Removal Shane1680 Jeep CJ Forum 4 04-21-2007 09:57 PM
Gas Tank removal from CJ georgecj6 Jeep CJ Forum 4 04-01-2007 10:02 PM
