CJ Fuse Panel - JeepForum.com
post #1 of 5 Old 06-23-2008, 10:09 PM Thread Starter
Chrisfol82
CJ Fuse Panel
I started redoing the wiring in my jeep and eliminating alot of the unnecessary wires.
My fuse panel as a few terminals that are broken, and as a result the previous owner spliced in some inline fuses in place of the broken terminls on the fuse panel.
Id like to replace the broken terminals so that i can run the wires though the fuse box as they should be and not through seperate inline fuses.
Anyone know if the little terminal connectors that fit into the fuse panel are available anywhere.
There are some that are single terminal, and some that are multiple terminal. I only have a few that are broken and dont really want to have to buy a whole wiring kit or new fuse box just because of a few bad connectors.
Other than that the wiring is all in good shape so i plant to reuse most of it and eliminate all the extra wires that AMC included that i dont think i need anymore.
Its an 84 CJ7
Chrisfol82 is online now
post #2 of 5 Old 06-24-2008, 01:20 AM
Uncle Russ
Uncle Russ's Avatar
Good luck finding the correct connectors to support your fuse block. On my 84, I ended up installing a Painless factory kit (which turned out to be anything but painless!) to fix the broken fuse block connectors plus bad connectors in the engine harness. In theory, you should be able to find the connectors since there shouldn't be anything special about them, they should be the typical fuse connectors used with the plastic bodied fuses. I had the same problem with my fuse block, the IGN LPS circuit was the primary trouble maker...the connectors broke off providing a less-than-reliable electrical connection on this circuit which I found to be the same circuit that powered up the stupid engine control computer. No computer, no running engine (when you're forced to maintain the smog spec!) for me!
Russ
“When you're swervin' on life's highway, you're runnin' someone off the road."
-- Robert Earl Keen
Uncle Russ is offline
post #3 of 5 Old 06-24-2008, 06:13 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I just stumbled across these when I was thinking about making a PCB for my dash:
http://www.globalsources.com/gsol/I/...1001699591.htm
http://enecomponents.manufacturer.gl...-Fuse-Clip.htm
http://www.keyelco.com/products/prod...bCategoryID=45
Key word is "ATC fuse clips" or holders
John Strenk is online now
post #4 of 5 Old 06-24-2008, 03:48 PM
Smtty58
Had the same problem on my GMC. Got replacement terminals from NAPA.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Smtty58 is offline
post #5 of 5 Old 06-24-2008, 07:40 PM
JohnnyRotten
1978 CJ5
Ron Francis sells the pig tails male and female google ron francis wiring they are on there somewhere I have bought them before. At least for my 79 CJ5 they were the same.
JohnnyRotten is offline
Fuse Panel Problems ??? Stan99 Jeep CJ Forum 14 02-02-2010 03:20 PM
cleaning engine compartment fuse panel? littleturner76 Jeep CJ Forum 3 08-16-2009 05:02 AM
78 CJ-5, more fuse panel turn signal prob's jimdubose Jeep CJ Forum 13 01-27-2009 08:18 PM
Fuse Panel Diagram '72 Cj5 whizerd Jeep CJ Forum 21 10-20-2008 12:09 AM
Fuse Panel Rebuild RetiredSERE Jeep CJ Forum 3 01-06-2008 12:15 PM
