CJ frame - JeepForum.com
post #1 of 31 Old 08-21-2013, 01:34 PM Thread Starter
bobert0670
1980 CJ7
CJ frame
So I decided to go new frame on my 80 CJ7 I looked at what I could buy and decided to have a local guy do mine. Now It's not mandrel bent but it does have every thing I want and even though its welded it still WAY stronger than factory and more than strong enough to handle what I plan on. If anyone is interested I can have him build as many as we need.
Robert
My first ever Resto project.
bobert0670 is offline
post #2 of 31 Old 08-21-2013, 01:49 PM
jdarg
Hope he has a frame table or it will be anything but straight.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #3 of 31 Old 08-21-2013, 06:47 PM Thread Starter
bobert0670
1980 CJ7
Yes it's not his first frame. I got his name from a friend who does work with Chip Foose. I think here will probably do a better job than most anyone.
Robert
post #4 of 31 Old 09-18-2013, 11:04 AM Thread Starter
bobert0670
1980 CJ7
So my new frame arrived, actually a few weeks ago but I have been traveling and did not get time to take the pics. So here it is, and one showing the old and new! Its Straight and STRONG.
He already blasted a few parts for me, and will be coming over to fill some of the "extra" holes in the body, and anything else I need. He will be making my front and back bumpers too.
Saved the original front crossmember
Plates added at weld points for strength
Where he could he cut cut a notch and bent, for added strength
This rear cross member should be just a touch stronger then the original
Old and New
Robert
post #5 of 31 Old 09-18-2013, 11:20 AM
jeepwhore
Looks good! What did it end up costing you?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #6 of 31 Old 09-18-2013, 11:50 AM
60scrambler
1982 CJ8
Looks good and strong, now to get hot dip galvanized.
Are you going to drill holes underneath at the low points for / as drains?
60scrambler is offline
post #7 of 31 Old 09-18-2013, 11:56 AM Thread Starter
bobert0670
1980 CJ7
Thanks guys, I am actually going to Epoxy paint instead of galvanizing, mainly because of cost. As for weep holes I have yet to determine that as well. The problem with holes is they also allow water to get in. However I will probably make drill some at the low spots, so it doesn't trap the water. All in all I paid 1300.00, but have talked with him and now that he has the specs the cost would be lower. for anyone interested let me know and I will get a firm price. I did not have to pay shipping so that helped out a lot.
Robert
post #8 of 31 Old 09-18-2013, 12:00 PM Thread Starter
bobert0670
1980 CJ7
And jeepwhore...... if that's your wife you are a lucky SOB! Congrats. I managed to out kick my coverage with when it comes to my girlfriend, it's nice but causes some anger when guys just blatantly stare!
Robert
post #9 of 31 Old 09-18-2013, 08:12 PM
mattl
Are you going to get it powdercoated? Looks great and decent price too.
1986 CJ7, AMC 360, NP435, D300, Tera60 w/Detroit, D44 welded, SOA, 37" MTR
mattl is offline
post #10 of 31 Old 09-18-2013, 09:32 PM
Jim1611
Jim1611's Avatar
I had mine hot dipped galvanized and it cost $185.00. Nice frame too by the way.
Jim1611 is offline
post #11 of 31 Old 09-18-2013, 10:24 PM
mattl
Epoxy coated. Sorry, I missed that. Keep the pics coming during the build-back.
mattl is offline
post #12 of 31 Old 09-19-2013, 09:38 AM Thread Starter
bobert0670
1980 CJ7
So I attached the front and rear shackle hangers. The suspension is a RE 4.5". Do the rear shackles look bad? I realize there is no weight on it yet, but I cant imagine the spring getting that much longer?
Next Step test fit the "New" 1984 Tub from Cali.
Robert
post #13 of 31 Old 09-19-2013, 09:39 AM Thread Starter
bobert0670
1980 CJ7
And YES I realize my garage is a disaster. Too much crap, I'm working on solving that problem though!
Robert
post #14 of 31 Old 09-19-2013, 10:51 AM
Renegade82
1982 CJ7
Those shackles are at the point of inversion. So if your springs were to flex / droop anymore, shackle inversion would be an issue. Are you sure he put the spring mounts in the correct spot and are the springs for the correct year? (not sure if spring lengths changed over the years or when)
Nice frame. I'd still recommend coating the inside of it though (or maybe you already did).
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #15 of 31 Old 09-19-2013, 12:04 PM Thread Starter
bobert0670
1980 CJ7
I mounted the shackle hangers, and I checked all his measurements, the problem is I could not find the correct measurements for the shackle hangers anywhere. I ended up using a straight edge to determine the location from spring hanger eye to Shackle hanger eye on the old frame. According to RE they are the correct springs for a 1980 CJ7. I have send an inquiry to their tech group to double check. What is the length of the Factory springs supposed to be? That is not in the FSM either.
Robert
