CJ File Sharing....DXF, DWG - Page 3 - JeepForum.com
 1Likes
post #31 of 59 Old 11-15-2013, 01:53 PM
EgulAye
1980 CJ5
Headlight relays
From a discussion on another thread, here is a quick sketch of a way to hook up headlight relays, using CJ style wiring numbers and device depictions.
Edit
I've finally started adding a headlight relay kit to one of my Jeeps and I used the above drawing as a starting point. One think I quickly decided is that I didn't really want to chop up the factory lighting harness. My old CJ had a lighting kit added to it when I bought it, which allowed switching between two sets of lights with a toggle switch. The other set of lights was not present on the Jeep when I bought it so the switch always needed to be in one position for the headlights to work. The harness used an H4 plug out at the driver's side headlight socket to get power from the headlight switch and fed it through the harness. At some point the toggle switch failed and I needed to get the lights working. Since the harness was an add on to the factory wiring all I needed to do was pull the H4 plug and swap the headlights back to the factory lighting sockets. This is also how I would prefer to add my headlight relay wiring.
So, I chopped the H4 plug from the failed lighting harness and have been building an add-on headlight relay wiring kit. I revised the previous drawing to show the new details and made terminal numbers match the relays I purchased. The terminal numbers match a couple of different relays but probably won't match with all of the possible relays one could use.
The drawing includes a diagram of the relay function so that its operation can be copied to whichever relay is purchased. Suggested wire sizes are on each conductor as well as colors that match the factory CJ and YJ wire colors.
These additional files are my "pre-fab" versions. I'll plan to replace them with final versions should I make any changes during the build process.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #32 of 59 Old 11-24-2013, 08:46 AM
scooby533
More!!!!!! The talents are awesome! Anyone have a drawing of a Meyer lower plow mount for a CJ7?
Shawn
scooby533 is offline
post #33 of 59 Old 12-04-2013, 10:26 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Shawn
I think I have an extra one that I'll see if I can make a drawing.
This is what I have, An old style Meyers lower plow mount
Is this what you need?
John Strenk is offline
post #34 of 59 Old 12-06-2013, 12:53 PM
John Strenk
1976 CJ5
Got some work done on it today.
The program I have does not export DFX files Sketchup 8
post #35 of 59 Old 12-07-2013, 07:21 PM
John Strenk
1976 CJ5
Here are a couple more details
post #36 of 59 Old 12-10-2013, 08:43 PM
scooby533
That's what Im looking for John! Mind if I PM you an email address?
This is the type of talent that needs shared. With today's manufacturing processes, we can keep these old beasts alive a while.
post #37 of 59 Old 12-13-2013, 09:19 AM
rodhead
dxf logo
Hello
Does anyone have the jeep logo dxf file?
rodhead is offline
post #38 of 59 Old 02-16-2014, 01:14 PM Thread Starter
WSS
WSS's Avatar
1972 CJ5
Does anyone have a d44 rear disc conversion bracket? I believe I am looking for 2.75" tube dia. and the caliper pattern for a chevy 3/4 ton late 70's.
Cheers!
WSS
WSS is offline
post #39 of 59 Old 03-01-2014, 10:40 AM
Spieg8
1984 CJ8
If you don't need a hard copy, you can download (FREE) FSM in PDF format here;
http://www.jeepforum.com/forum/f8/84...ml#post6991784
Spieg8 is offline
post #40 of 59 Old 03-18-2014, 11:48 AM
midd66
Is it ok to create a CAD file from the wiring diagrams in manuals and post them? If so, I will try to get those converted to CAD and post the up, I am about to be doing some wiring on my cj7 anyway.
midd66 is offline
post #41 of 59 Old 03-18-2014, 01:20 PM Thread Starter
WSS
WSS's Avatar
1972 CJ5
^^YES!^^
Post em up, wiring diagrams are very helpful.
WSS
WSS is offline
post #42 of 59 Old 03-18-2014, 08:24 PM
midd66
I know, they are making my life alot better right now. I can make a good diagram with what I have now, but I think I could make a bad @$$, over the top, diagram if I could get a copy of what I have without having to cut and tape it together. I will work with what I have, but let me know if anyone hears of someone that has access to the real deal.
midd66 is offline
post #43 of 59 Old 05-27-2014, 05:08 PM
350sierra
Here's a quick front bumper I borrowed from 3d warehouse and dimensioned out...bumper.jpg
350sierra is offline
post #44 of 59 Old 05-28-2014, 04:43 PM
350sierra
post #45 of 59 Old 05-29-2014, 08:21 AM
ikidd
Anyone have a CJ7 dashboard laid out in DWG?
Edit: Found one I missed earlier in the thread, now I can't figure out how to delete this post.
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline
cad , cj , cnc , dwg , dxf
