CJ File Sharing....DXF, DWG - Page 2 - JeepForum.com
 2Likes
post #16 of 59 Old 06-18-2013, 08:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I was doing some drawings to explain how things work.
I'm not very good at it though.
John Strenk is offline
post #17 of 59 Old 06-18-2013, 10:40 PM Thread Starter
WSS
WSS's Avatar
1972 CJ5
You did good until the fourth image. What is it?
WSS
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is online now
post #18 of 59 Old 06-19-2013, 07:58 AM
John Strenk
1976 CJ5
WSS
Suppose to be a carburetor venturi with booster and fuel bowl with passage to booster.
Trying to explain carburetor principle.
Just found a new animation program for this stuff and it's free.
post #19 of 59 Old 09-11-2013, 05:15 AM
VooDoo2
1978 CJ7
http://www.3dcadbrowser.com/download.aspx?3dmodel=2912
Jeep CJ7 3D Model for 3ds Max, Maya, Cinema 4D, Lightwave, Softimage, Blender and other 3D modeling and animation software.
This 3D object can be downloaded in .max, .obj, .3ds, .fbx, .dxf, .lwo, .kmz, .lxo, .stl, .wrl, .ma, .xsi, .dae, .iv, .pov, .x and .asc file formats.
VooDoo2 is offline
post #20 of 59 Old 09-26-2013, 12:41 AM Thread Starter
WSS
WSS's Avatar
1972 CJ5
Intermediate CJ5 cage details.
Thought I had posted but can't find it
WSS is online now
post #21 of 59 Old 09-26-2013, 06:23 PM
eddieburnsii
1980 CJ5
I been playing with this today. It is from my 1980 CJ5. Can anyone verify that it is correct or close enough?
eddieburnsii is offline
post #22 of 59 Old 10-18-2013, 11:09 PM
eddieburnsii
1980 CJ5
For IrishCJ6 and anyone else interested.........1980 CJ5 dxf I drew. I haven't cut one out yet so use at your own risk. I took the liberty of widening the rear floor section 1" and there are a few other things I did differently than stock.
post #23 of 59 Old 10-27-2013, 03:34 PM
John Strenk
1976 CJ5
Nice stuff
post #24 of 59 Old 11-06-2013, 02:43 PM
EgulAye
1980 CJ5
Trying to gauge interest on a CAD version of the wiring diagrams...
I'm about 60% done making a CAD file from one of the old jpeg images of a CJ wiring diagram. I'm guessing a live CAD file may be of use to some?
It would be especially handy if you have CAD and want to change things to match your existing Jeep... I plan to make each wire a polyline, meaning that if you select it in CAD then the whole wire is selected, from end to end. Guess we'll see, I've been chipping away at it when other Jeep stuff isn't more pressing.
I could post a work in progress if anyone wants to see what it looks like right now. If enough people would want it I could probably step up my attention to getting it done.
mock poll:
  • CAD files for wiring diagrams are pointless
  • CAD files for wiring diagrams would be the bomb!
  • I'd trade a ton of CJ parts for a CAD file of the wiring
  • I already have a CAD file for the CJ wiring, I just didn't share here
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #25 of 59 Old 11-06-2013, 07:00 PM Thread Starter
WSS
WSS's Avatar
1972 CJ5
^^Bring it on!^^
Does not have to be loaded as a dxf, cad or dwg as it is for reference. A pdf or jpg is cool.
Are you doing "color correct" type of drawing?
If you post what you have, some may be able to critique it and give some suggestions too.
I have no idea w/electrical but am all up for learning about it and following along.
WSS is online now
post #26 of 59 Old 11-06-2013, 07:59 PM
EgulAye
1980 CJ5
Right now I'm doing it like the factory diagrams. All the wires are one color, with wire numbers, color, and size labels. At the moment I've created layers for wiring, devices, text, optional items, vacuum lines, ported vacuum, title block, etc. I also just realized that I've been doing a '78 wiring diagram that has the glass AGC type fuses instead of a '79 or newer with the ATC type fuse block. My CJ is an 80 so I should have been doing a newer version for my own benefit. Dangit!
I'll clean the '78 drawing up a bit and post it, with a raster reference file. Once it's done it will be all digital, but for now you'll want to see the image portion for what I haven't drafted.
2012 JK
EgulAye is offline
post #27 of 59 Old 11-06-2013, 08:29 PM
EgulAye
1980 CJ5
So, I just dropped in a different image for the drawing because the one I was using had "issues". Another slight glitch, the forum doesn't support uploading TIF images, so I'll be sure to post it again later with a JPG instead, for now it will be a broken reference. I noticed a few discrepancies so there is even less done than I thought. I had been doing just the 6 Cyl portion of the engine side, and planned to put the vacuum diagram in it's place for my own application. For now the vacuum portion is off to the side and the V8 wiring is untouched.
This is sounding less and less attractive all the time
Just save the image and the CAD file to a folder on your PC (both to the same folder) and open the AutoCAD file.
2012 JK
EgulAye is offline
post #28 of 59 Old 11-06-2013, 08:36 PM
EgulAye
1980 CJ5
Here's a .jpg version of the image I'm using... The TIF I'm using is a better resolution, but at 8MB it won't fit here. I shrank it to 75% and it's compressed as a jpeg.
2012 JK
EgulAye is offline
post #29 of 59 Old 11-13-2013, 01:39 PM Thread Starter
WSS
WSS's Avatar
1972 CJ5
Here are the skid plate dxf's for a CJ5 intermediate (Mines a '72)
One piece is for guys with a wide press brake, the two piece is for guys with a swag brake. The sides gussets need two pieces cut to complete a skid plate.
cheesie fone pic
WSS is online now
post #30 of 59 Old 11-13-2013, 01:45 PM Thread Starter
WSS
WSS's Avatar
1972 CJ5
Here is dual Optima battery tray with hold downs. The two vertical hold downs are a little long so you can cut with a cut off saw or whatever you have to fit your particular length. I put a 1/4" piece of open celled rubber under mine. If you skip the rubber, yours will need to be shorter of course. One side (the outboard/pass side) on mine is hinged as it will be used for lend power at times, the hinge allows the batt to slide out and not have to be lifted straight up. You could hinge both sides or neither if you will leave them in all the time.
A is main tray with bend notches.
B is divider (w/ my logo, put in your own or pm for a custom one)
C is top clamp struts, you need two bent the same
D is long vertical arm
E is short vertical arm
cut one of each D and E or two of one depending on your needs. They are the same, just one is .25" longer and easy to trim to a custom length.
Cheers!
WSS is online now
cad , cj , cnc , dwg , dxf
