Cj fenders - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cj fenders
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 06-29-2012, 08:56 PM   #1
Samcro
Junior Member
Cj fenders
Can someone please tell me if a YJ fender will fit on a CJ?
Samcro is offline   Reply With Quote
Unread 06-29-2012, 09:12 PM   #2
lucdog
just a jeep guy
lucdog's Avatar
1980 CJ5
No, won't fit without the YJ grill ( it's wider)
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote
Unread 06-29-2012, 09:13 PM   #3
BlkCJ7Laredo
Absolutley!
To use the YJ fenders you must fill the holes for the hood hold-downs and move them, also you must fill the front three bolt holes that attach the YJ fender to the grille. The two rear holes you re-use but the bottom hole you must drill a new hole in the grille and put a nut on the backside.
I am now changing back to CJ fenders during my rebuild/mild restore project.
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote
Unread 06-29-2012, 09:19 PM   #4
lucdog
just a jeep guy
lucdog's Avatar
1980 CJ5
Originally Posted by BlkCJ7Laredo
Absolutley!
Dont the fenders need pulled in to the grill?
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-29-2012, 09:30 PM   #5
Samcro
Junior Member
They are fiberglass fenders.
