CJ Driveshaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ Driveshaft
WJ Tube Doors Now Available!*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*TJ 5.25" Speaker Adapters - NalinMFG
Unread Yesterday, 08:36 AM   #1
karenmascaro
CJ Driveshaft
Ok no it is not a true Jeep with this drivetrain but it is what is here and I am looking for an answer any help appreciated.
1986 CJ7, 4.3 Chevy with a 208 Transfer case and a 700R4 Auto Tranny, rear Driveshaft has snapped, I assume I will need to have one custom made??
Thanks
Karen
karenmascaro is offline   Reply With Quote
Unread Yesterday, 08:50 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Looks like a Jeep from here.... I think I would find a local driveshaft builder and have a stronger one built. Unless you just blew an ear off a yoke? That can happen when a u-joint blows out. Then another of what you have in there would do with u-joints you can grease every run. I get water out of mine every time I grease it after a run.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread Yesterday, 08:51 AM   #3
karenmascaro
Thanks Mike
Unread Yesterday, 09:10 AM   #4
dg6772
Personally,I think I would take this opportunity (maybe) lose that 208 and put in something with a yoke for the rear driveshaft. Or a kit to convert it. As you know; lose the rear shaft and you're done....
That said....d&r driveline makes an awesome driveshaft. I've seen them in car magazines,but they are local to me. Comparable to Tom Woods? Well,I don't know about that, but reliable and reasonable. Most of all,I've never had one fail( knock, knock,knock) yet.
(616) 667-1308 is D&R's contact number,if interested.
If using a local vendor,take the time to do some research. I used one right here in town and had to keep returning it because the welder did a crappy job. Even accused us of having too much power. Ha,that CJ7 had a 258 backed by a 999 with a body lift and 33's. Too much power?? I think not!
Good luck.....
Dave in Muskegon using JeepForum
dg6772 is offline   Reply With Quote
Unread Yesterday, 09:57 AM   #5
karenmascaro
Thanks Dave
Unread Yesterday, 10:54 AM   #6
Cutlass327
Cutlass327's Avatar
1978 CJ5
Also, verify that your angles are ok. If the length of the driveline makes the rear driveshaft too steep, you may be binding it up and causing issues. When I put the T177/D300 in my '5 I had issues with the yokes binding at the rear axle. I had to clearance the one yoke a little with a grinder just so I could move it without them hitting each other. I have since went to a double cardan style shaft from a XJ. Pull-a-part front driveshaft, had the local builder shorten it to the needed 15.25 inch length, and angled the rear axle as needed. No more vibrations or worries.
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote
Unread Yesterday, 11:07 AM   #7
80cj
80cj's Avatar
1980 CJ5
I've seen the drive shafts that Tatone builds. He uses very heavy duty components.
80cj is offline   Reply With Quote
