CJ Door Lock Assembly - JeepForum.com
post #1 of 16 Old 08-25-2008, 11:04 AM Thread Starter
joemac421
joemac421's Avatar
Does anyone know where to buy the lock assembly inside the door. I am not talking about the lock cylinder I am talking about the metal thing with springs that all the rods connect to and move to actuate the door locking and opening?
Better to have Jeeped & Rolled Over then to never have Rolled Over.
joemac421 is offline
post #2 of 16 Old 08-25-2008, 12:37 PM
craigb86
Here is some on ebay.
Craig
craigb86 is offline
post #3 of 16 Old 08-25-2008, 03:51 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Craig
Uh, those have nothing to do with opneing/closing/locking the door. It says right in the title that they are window regulators.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #4 of 16 Old 08-25-2008, 03:55 PM
craigb86
bah you got me
Go to a junkyard and rip them out of a 1989-1995 wrangler they are the same type door.
Craig
craigb86 is offline
post #5 of 16 Old 08-25-2008, 09:03 PM
cyclic17
1981 CJ7
I have been looking for the same thing for months, and FINALLY found them on ebay last week.
No one makes them aftermarket (4wd.com, Quadratec, etc). I've checked with Collins Bros and another Jeep scrapyard with no luck. Keep searching ebay and the For Sale section here for guys that are parting out their junk.
Or, like craig said, see if you can find a YJ that has the same post-type striker on the tub.
Good luck!
*'81.5 CJ7, D300, T-5, 258ci, 4" BDS lift, 33 's on 15x10 Bajas, Narrowed Waggy D44 Front, Scout D44 rear w/ARB locker, Not-so-Painless Wiring Harness, Warn 8274, Borla Headers, MC2100 carb, Shrockworks sliders, KC's, Full cage
*RIP: '88 Comanche Chief, stock except for KC lights on rollbar and custom stereo.
cyclic17 is offline
post #6 of 16 Old 08-25-2008, 10:45 PM
PavementPounder
Cool as Ice...
I found a passenger side while searching the garage. Is this what you're looking for?
post #7 of 16 Old 12-02-2009, 07:01 PM
isalter
1981 CJ7
Still have?
DO you still have these pieces?> I am looking for the metal piece that the lock mech is attached to and the rods inside the door.
isalter is offline
post #8 of 16 Old 12-02-2009, 07:30 PM
tomthbomb
CJ7 1/2 Top Club mem. #1
tomthbomb's Avatar
1978 CJ7
Hope you have better luck than I did.
I locked the passenger side door and now I can't get it unlocked with the key or the inside rocker.
Guess I will have to take the door off at the hinges unless somebody has an idea I am to dull to think of.
1978 CJ-7 original owner; AMC 401 V-8 (w/some goodies);NP4500;D300 (w/Curry 4:1); D44 front;AMC20 (Warn one piece axles) rear
tomthbomb is offline
post #9 of 16 Old 12-02-2009, 07:48 PM
isalter
1981 CJ7
THata real bummer.. I hope I dont have that issues. I am thinking though that even with the hinges off that wont undo the locks though.. At least with mine as they wrap around the piost when locked..hmmm
isalter is offline
post #10 of 16 Old 12-03-2009, 06:29 AM
1984CJ
1984CJ's Avatar
Tom,
Assuming you have the paddle handles You will have to in from the inside of the jeep, remove the interior panel and trip the latch from inside the door. Trying to remove it from the hinges will not help. Lever styles are probably different.
I have the same problem with one of my doors. I have to constantly remind my wife to NOT LOCK THE DOOR when she rides with me.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #11 of 16 Old 12-03-2009, 06:49 AM
isalter
1981 CJ7
84CJ is on it! That will work, I was lookign at mine a little while ago as I have the panel off and yes you can get to it. Tight but it can be done. Good luck Tom!
isalter is offline
post #12 of 16 Old 12-03-2009, 07:13 AM
Mike Romain
Lots of tow truck drivers have slim jims that can usually pop the lock open from the outside.
Mike
Mike Romain is offline
post #13 of 16 Old 12-03-2009, 07:15 AM
Mike Romain
What about a GM van or pickup? The latch looks the same I think and AMC (all makers covered) liked to use GM stuff like the wiring and steering to name a couple.
Mike
post #14 of 16 Old 12-03-2009, 07:21 AM
Area.3.Fiftyone
Isn't what PavementPounder posted (latch assembly) what you are looking for?
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #15 of 16 Old 12-03-2009, 08:09 PM
PavementPounder
Cool as Ice...
I never heard from Joemac about the latch I posted. Still have it, but only have the passenger side and not a pair.
Old, rusty doors are fine as a source. You just need to pull the latch assembly, clean it, and grease it thoroughly before swapping it in. Lack of lubrication is what leads to things bending.
NEED passenger door assembly for 86 cj7 monique1016 Jeep CJ Forum 0 01-18-2010 06:51 PM
pre 1981 Door re-Assembly LostINohiO Jeep CJ Forum 0 10-05-2008 10:23 PM
Hub assembly outer lock nut size 390fastback Jeep CJ Forum 2 10-06-2005 07:47 AM
84 cj door lock blacksambellamy Jeep CJ Forum 2 03-02-2005 08:49 AM
'86 CJ7 hard door interior plastic open lever/lock/unlock assembly edge1 Jeep CJ Forum 4 07-16-2003 09:19 AM
