CJ dies after about a min. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ dies after about a min.
LOCKERS!!!! - ARB, Auburn, Detroit, Eaton, OX, Spartan, YuRIGID LED Light Blowout Sale - All Sizes, All Series, all ECGS Black Friday Sale!!
Unread 11-17-2014, 03:17 PM   #1
pirate94
1983 CJ7
I have been fighting several problems with my "83 258. I have a new Carb, New fuel tank. Fuel lines have been blown out. New fuel filters. New sending unit. New fuel pump.
Choke is finally working. Takes a while to start, Idles fine, then dies after about a minute. Sounds like a fuel problem.
Any help would be great.
pirate94 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2014, 03:31 PM   #2
pirate94
1983 CJ7
Also, do I have to use the thee prong fuel filter for the tank vent lines, or can I cap the vent line?
Unread 11-17-2014, 04:00 PM   #3
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The third hole in the OEM style fuel filter is a fuel return line, not a vent. It regulates pressure to the carb, and is said to help prevent vapor lock. Why would you cap it?
The fuel tank vents thru a separate line that connects the tank to the vapor canister.
Your problem sounds like an improperly adjusted choke. What type of carb do you have?
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 11-17-2014, 08:46 PM   #4
pirate94
1983 CJ7
Carter BBD
Unread 11-17-2014, 08:48 PM   #5
pirate94
1983 CJ7
Even if I keep RPM's up. Engine will still die.
Unread 11-17-2014, 08:49 PM   #6
pirate94
1983 CJ7
What part of choke do you think is out of adjustment?
Unread 11-17-2014, 10:14 PM   #7
dg6772
Does your engine sputter out and die, or shut down like you turned it off. Sputter leads to fuel, quick shutdown leads more towards electrical. Coil, ignition circuit, etc. My friend chased fuel for a long time before realizing it was electrical. Just a thought....
Dave in Muskegon using JeepForum app
dg6772 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2014, 10:49 PM   #8
pirate94
1983 CJ7
sputters and dies.
Unread 11-18-2014, 12:37 AM   #9
Matt1981CJ7
1981 CJ7
You said the choke is "finally working". Describe how it functions.
Matt
Unread 11-18-2014, 03:23 PM   #10
pirate94
1983 CJ7
During a cold start butterfly is closed, with a small gap in the barrel. After running for a short time butterfly starts to open. Is this what you are looking for?
Unread 11-18-2014, 06:26 PM   #11
davegt
1983 CJ5
If it dies after a min for so and the choke is already opening up then that's your problem. Choke is opening too fast
davegt is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 07:14 PM   #12
rickscj7boom
hold the choke and see if it stays on..
rickscj7boom is offline   Reply With Quote Quick reply to this message
Unread 11-20-2014, 09:54 PM   #13
pirate94
1983 CJ7
Holding choke open made no difference. After several start attempts engine idled well for about 15 min. Test drive was a huge failure. As soon as clutch was engaged engine died. Then wouldn't start. After next start same thing, died as soon as under load. WTF???!!!
Unread 11-20-2014, 10:06 PM   #14
Jeepn-n-tx
I went by Mike Honcho...
Jeepn-n-tx's Avatar
1981 CJ7
Could be vacuum leaks .... those damn things can throw a carb all kinds of out of whack.
Is everything stock or have you made lots of changes? Have to you rerouted vac lines and forgotten one? Picks would help us immensely.
Is it snobby I don't wave at 4-door Jeeps? :)
-Scott
'81 CJ7 Rebuild ... http://www.jeepforum.com/forum/f8/my...oject-1543726/
Jeepn-n-tx is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 07:30 PM   #15
rickscj7boom
vacuum leaks are hell.. I had one on my 84 and thought it was my carb until I came on this site and was straightened out by the guys. so you already checked to make sure the card is getting fuel? are you using the correct fuel filter with return line back to tank?
