CJ Dash Restoration.... that classic look! - Page 7 - JeepForum.com
 5Likes
post #91 of 333 Old 01-16-2011, 01:20 PM Thread Starter
keith460
Jeep. There's Only One
keith460's Avatar
New cover came from our shop and is made from 1/4 thick polycarbonate stock.
Drilled the holes for the time adjustment knob and locating pins so the new cover sits in the original locating holes on the clock face. This type of job is not for the novice person to do but it can be done if measurements are made precisely so everything fits together. Drilling the holes for the locating pins is the most difficult as they must be exactly 2.75 inches apart and I made my own pins out of an old U-joint needle bearing that was cut in half. Then the cover must be drilled undersized for the pins to be pressed in. First cover I made, the pins were slightly off so I had to make another cover that hit the mark the second time around. Good thing I made 6 covers as spares just in case I needed them.
1984 CJ-7 Renegade
keith460 is online now
post #92 of 333 Old 01-16-2011, 05:02 PM
Graffxman
1976 CJ7
Are you going with a new wiring harness?
Graffxman
'76 CJ7--304 V8
Graffxman is offline
post #93 of 333 Old 01-16-2011, 05:27 PM Thread Starter
keith460
keith460's Avatar
Nope, nothing wrong with the one I have as it is an unmolested original. I will be adding dedicated ground wires though.
1984 CJ-7 Renegade
post #94 of 333 Old 01-16-2011, 07:03 PM
Graffxman
1976 CJ7
The wiring is the part I'm waiting for. Good pics are appreciated, I'll be studying them in detail.
Beautiful job so far!
Graffxman
'76 CJ7--304 V8
post #95 of 333 Old 01-18-2011, 01:54 PM
JrTjK
1978 FSJ Wagoneer
Originally Posted by sgtbookie View Post
I ran into the same issue with the Crown lights. One of there employees is a regular on here and asked for pictures and a description of the problem. Never heard back on a solution, but would really love them to replace my floor board lighting with an updated set. Definately want to hit them with some paint if you get those ones.
Just wanted to update after I saw this, the Crown lamps that are in/going out now as of December are corrected and should be like originals. The housings are now opaque white and the output color was adjusted so these should be as good as factory. I've seen them in person and they look great!
Keith, beautiful work on your dash!
JrTjK is offline
post #96 of 333 Old 01-18-2011, 08:27 PM
Boodyrider
That is absolutely beautiful.
Any chance you'll make more for resale? I'd be interested, and I could see these being very popular among resoration guys. I wonder how rapidly they could be made with CNC on the pin holes?
Seriously... you do NICE work.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #97 of 333 Old 01-18-2011, 10:54 PM Thread Starter
keith460
keith460's Avatar
Any shop with a water jet machine can pop them out quickly and cheaply. I could provide the exact measurements for the replacement cover piece if needed.
I installed the clock and tachometer but haven't posted pictures yet as I am now in Milwaukee WI on business. Will post when I get back and then I will start on the radio installation and modification to add a mini stereo jack (1/8") for an auxiliary cord to play an MP3, IPod or whatever to the radio using the factory volume control knob to adjust sound level.
1984 CJ-7 Renegade
post #98 of 333 Old 01-18-2011, 11:01 PM Thread Starter
keith460
keith460's Avatar
Have you bought any of the new dash lamps? I would like to buy a set of the new and improved ones but I would be afraid that I would receive old inventory off the shelf from one of the vendors out there.
1984 CJ-7 Renegade
post #99 of 333 Old 01-18-2011, 11:56 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Yeah, my wiper lamp is out, and have thought about getting a new one. Maybe I'll wait a few months to order - let the old inventory get used up
Rick
Cutlass327 is offline
post #100 of 333 Old 01-19-2011, 10:01 PM
Boodyrider
I'll let you all know what the ones from Morris 4x4 look like. I just ordered the set of 6 last night.
post #101 of 333 Old 01-20-2011, 08:57 PM
Davidnex
1979 CJ5
MOD to OEM radio
Needed to cut hole slightly larger than OEM
Radio adapter
New radio
OrangeCJ-5 likes this.
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #102 of 333 Old 01-20-2011, 09:26 PM Thread Starter
keith460
keith460's Avatar
Ouch!
I'm sorry but I cringe every time I see a perfectly good CJ dash that gets cut for a DIN (Duetsch Industrial Normalization) radio cutout. It makes me cry sometimes seeing that but sometimes there is no choice in this world we live in today. Out with the old, in with the new I guess.
1984 CJ-7 Renegade
post #103 of 333 Old 01-20-2011, 09:35 PM
boomvader
I hear ya, Keith. I am going the other direction. I am going to have Dan with Double D fab make a custom dash similar to this picture and I will have it painted red with the rest of the Jeep and install a matched set of autometer gauges. I will install the stereo in a tuffy center console. I like the look of the classic dash, but the aftermarket gauges suck, the bezels do not seem to match for all of the gauges, etc. and I would like mechanical gauges for oil and water.
However, I understand what your goal is and also cringe when somebody hacks a perfectly good dash (I actually have done it) or, even worse, butchers a straight, rust free tub for rock crawling purposes... OUCH.
Thanks for the explanation for DIN. I just learned something! :-)
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #104 of 333 Old 01-20-2011, 09:43 PM
Davidnex
1979 CJ5
Ouch!
Keith, I knew this would get to you.
Davidnex is offline
post #105 of 333 Old 01-20-2011, 09:51 PM Thread Starter
keith460
keith460's Avatar
I'm still crying over my beer I'm drinking.
1984 CJ-7 Renegade
cj2 restoration mxer Jeep CJ Forum 1 01-20-2011 09:41 PM
dash pad restoration help Baloo Jeep CJ Forum 10 01-08-2011 02:58 PM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 02:33 PM
Best way to start a classic restoration? 85 Srambler original owner - no engine SomerJeep Jeep CJ Forum 7 06-11-2007 08:51 AM
78' CJ Restoration w/ 87' YJ tub Vidman35 Jeep CJ Forum 3 03-29-2005 11:57 AM
