CJ Dash Restoration.... that classic look! - Page 21 - JeepForum.com
 4Likes
post #301 of 330 Old 01-05-2014, 07:07 AM
GlennLever
GlennLever's Avatar
Originally Posted by VooDoo2 View Post
Mines getting close now and its the RIGHT way around too
Gotta find a stereo and speakers (damn PO hacked them) and get the tacho working with a HEI distributor.
What are your plans for fixing the holes?
Find a donor dash?
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #302 of 330 Old 01-05-2014, 09:56 AM
SKT
1981 CJ7
Gotta find a stereo and speakers (damn PO hacked them)...
Try finding another unmolested RHD dash...
Here's some RHD porn/motivation for you, thanks to JerseyJeeps' beautiful Overlander:
Here are a couple links to a lot more details/pics of his Overlander:
http://www.cj-8.com/forum/showthread...e-Improvements
http://www.cj-8.com/forum/showthread...Now-what/page2
Good luck!
SKT is offline
post #303 of 330 Old 01-05-2014, 03:08 PM
GlennLever
GlennLever's Avatar
Attachment 971274
Attachment 971282
Attachment 971290
Attachment 971298
Good luck!
But the steering wheel is on the wrong side
Glenn R. Lever
My Web Site
post #304 of 330 Old 01-05-2014, 05:07 PM
rixcj
rixcj's Avatar
1979 CJ5
Try finding another unmolested RHD dash.... you think you guys have it hard finding parts. You have it EASY.
I'll bet that you could get one made here...
http://www.doubledfab.com/
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #305 of 330 Old 01-06-2014, 04:59 PM
O1dSoldier
1978 CJ5
I see you have an A/C in your Jeep. I don't have it in mine but during my rebuild I have thought of adding it, not that the weather in Washington requires it but because its not seen very often in a CJ but wonder if its worth the expense. Any thoughts anyone?
O1dSoldier is offline
post #306 of 330 Old 01-06-2014, 05:12 PM
CJShayne
I would absolutely love to have an A/C unit in my CJ. ClassicAir has a nice unit. (Or so I'm told)
CJShayne is offline
post #307 of 330 Old 01-07-2014, 12:58 PM
wm69
www.jeepair.com
wm69 is offline
post #308 of 330 Old 08-28-2014, 10:29 AM
smbundy13
1980 CJ7
if I am going to re-wire my jeep with a full painless harness and my dash is already out.. could I just wire all of the dash up first and then install it back on the tub? seems like that would be easier to do than hang upside down under the dash.
thanks.
DD - 2013 Ford F150 Platinum Eco-Boost
1980 CJ-7 rehab in progress
smbundy13 is offline
post #309 of 330 Old 08-28-2014, 06:54 PM
PanteraPilot
1978 CJ5
Well Keith, I'm just picking up on this thread that has been around for years. I see its still going. My compliments on you excellent job.
PanteraPilot is offline
post #310 of 330 Old 08-28-2014, 08:46 PM
CrankyD
1983 CJ7
Dead thread revival alert! I had some bolts about 8 inches long that were the same size as the windshield knob thread (3/8"-16 I think) that i used to hold the dash on and let me work behind for wiring. Once I had it all on as good as I was going to get it I mounted the vent cables, speedo cable and steering column cover.
CrankyD is offline
post #311 of 330 Old 08-29-2014, 04:40 AM Thread Starter
keith460
Jeep. There's Only One
keith460's Avatar
I'm with you, used the same threaded windshield knob holes to hold the dash panel out while completing the wiring hookups. Made the mistake of putting in all the vent cables while the dash was out only having to remove them as I was not able to route them easy.
I'll be back on this thread soon as some of my POS Crown vent cable knobs have pulled off the stems. Looking to insert some threaded inserts made for plastic into the knobs and then thread the cable rods with a Die and screw the knobs back on. Sent from my iPhone using JeepForum
1984 CJ-7 Renegade
keith460 is offline
post #312 of 330 Old 08-29-2014, 08:47 AM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Hey Keith I purchased a set of Crown dash cables some time ago and the label said Made in USA and the mold stampings on the inner parts of the cables that snap into the dash were the same as the OEM cables I took out, leading me to believe that Crown went to the same supplier that made the cables for AMC/Jeep. I then purchased more cables more recently, and now they are made in China.. It looks like you may be suffering from the same problem. I can't say the originals were much better though. I know that I used epoxy to reattach the knobs on my originals way back when they were in there and that worked well. Would save you from having to pull the whole dash out.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #313 of 330 Old 08-29-2014, 08:58 AM
Mike Romain
thanks.
I did mine on my coffee table, then took it out and put it on.
Mike
Mike Romain is offline
post #314 of 330 Old 08-29-2014, 02:08 PM
smbundy13
1980 CJ7
awesome tahnks.
post #315 of 330 Old 09-07-2014, 09:31 PM
Mortgage-payer
1976 CJ7
Real informative thread - thanks!
Mortgage-payer is offline
cj2 restoration mxer Jeep CJ Forum 1 01-20-2011 09:41 PM
dash pad restoration help Baloo Jeep CJ Forum 10 01-08-2011 02:58 PM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 02:33 PM
Best way to start a classic restoration? 85 Srambler original owner - no engine SomerJeep Jeep CJ Forum 7 06-11-2007 08:51 AM
78' CJ Restoration w/ 87' YJ tub Vidman35 Jeep CJ Forum 3 03-29-2005 11:57 AM
