CJ Dash Removal? - JeepForum.com
post #1 of 5 Old 02-28-2010, 08:55 AM Thread Starter
Conch Cruiser
1983 CJ7
CJ Dash Removal?
I'm getting my plans together to restore my 83 CJ7.
I've been reading posts on this forum and gathering ideas and information. Great site.
On one of the "Jeep Build Threads" it looked like someone pulled the dash out and all the wires stayed on the guages and etc. as if they were disconnected at the firewall.
Is that the case?
I saw another "Jeep Build Thread" where it looked like he pulled the dash and all the wires stayed attached to the firewall.
If it can be doen both ways, which is better?
I think I would like to pull the dash leaving the wires connected to the guages and etc.
Conch Cruiser is offline
post #2 of 5 Old 02-28-2010, 09:45 AM
Mike Romain
I would start using penetrating oil on the hinges now and use lots unless you know they will move. Most are seized and just bend, then you need new ones.
The fuse panel comes apart at the firewall. There are a couple small screws in it and one big center bolt on the engine side that pulls it all apart. You end up with a dash harness piece, a tail harness piece, an engine harness piece and a front light harness piece.
If you need any light plugs or sockets, a harness from a full sized GM van that hasn't been open to the weather has all the same parts.
Here is a link to the FSM for the 84-86 that should be real close to yours: 84-86 Factory Service Manual... - JeepForum.com
Mike
Mike Romain is offline
post #3 of 5 Old 02-28-2010, 10:08 AM Thread Starter
Conch Cruiser
1983 CJ7
Thanks Mike, That is how I had if figured out. I appreciate the verification.
post #4 of 5 Old 02-28-2010, 10:17 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I like leaving all the wires on also. Just some minor stuff like brae light switch and dimmer switch and rear harness has to be disconnected. You'll see as you pull it out.
John Strenk is offline
post #5 of 5 Old 02-28-2010, 11:27 AM
PERK
make sure you read the section on pulling the steering colum.
PERK is offline
Dash Pad Removal - What am I missing?? IdahoJeeper Jeep CJ Forum 3 08-07-2009 09:25 PM
Dash removal process twoleos617 Jeep CJ Forum 7 01-19-2009 12:37 PM
CJ dash pad removal... danholovic Jeep CJ Forum 9 08-26-2008 06:10 PM
84 CJ7 dash pad removal question WolfDawg Jeep CJ Forum 3 08-03-2008 05:46 PM
dash removal question jeromehdmc Jeep CJ Forum 11 01-07-2008 12:13 PM
