CJ Dana 44 ID - JeepForum.com
post #1 of 28 Old 08-24-2010, 03:51 PM Thread Starter
mtndew1
1976 CJ7
CJ Dana 44 ID
I picked up Dana 44 that was advertised as being out of an 86 CJ but I'm starting to wonder if it really was. I need some help figuring out what it's out of if not that.
Width - Stock Wide Trac
Brakes - 11" Drum
Bolt Pattern - 5x5.5
Pumpkin = Centered
Everything I've ready says the brakes on a Dana 44 should be the same as the Model 20 and be 10" Drums not 11". Is this correct or what axle could have been cut down to make this?
Would the numbers if any on the Dana 44 help me confirm what it's out of?
Thanks,
Andrew
1976 Jeep CJ7 - Build in progress
mtndew1 is offline
post #2 of 28 Old 08-24-2010, 04:02 PM
CSP
Go to post #7 in this thread to see how to 100% positively ID the axle you have.
http://www.jeepforum.com/forum/f8/ax...worth-1092934/
CSP is offline
post #3 of 28 Old 08-24-2010, 04:46 PM Thread Starter
mtndew1
1976 CJ7
That is fantastic, just what I was looking for. I wish I had know this before I bought it.
Thanks,
Andrew
mtndew1 is offline
post #4 of 28 Old 08-24-2010, 05:02 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Someone might have swapped on the drums from a 72-75 CJ D44? I think the backing plate pattern is the same.. could be wrong though.
BESRK is offline
post #5 of 28 Old 08-24-2010, 06:14 PM Thread Starter
mtndew1
1976 CJ7
The 11" drums don't look like the older Jeep ones at least from the pictures I've seen of the replacement parts.
I can't seem to find any bill of Materials numbers on the tube and there are no tags on it any longer. I found stamped in the pumpkin C35832.
Is there any other place I could find the Bill of Materials number or other way to identify it. Perhaps if I pull the axles there will be a number on them?
Thanks,
Andrew
mtndew1 is offline
post #6 of 28 Old 08-24-2010, 07:23 PM
foggybottombob
The only 56" WMS to WMS rear Dana 44 semi floating 5 on 5.5" axle I am aware of is the 86 CJ one. If it has not been cut down then that is what it is. I do not know anywhere to get axle shafts for one of those.
foggybottombob is offline
post #7 of 28 Old 08-24-2010, 08:48 PM Thread Starter
mtndew1
1976 CJ7
I'm pretty sure it's 56" wheel mount to wheel mount. It even says 56 on the ends of the axles.
mtndew1 is offline
post #8 of 28 Old 08-24-2010, 08:50 PM Thread Starter
mtndew1
1976 CJ7
The better question is since it's 11" drums and I want to rebuild the brakes, what parts should I try? All of the 86 jeep parts seem to be 10" drums. I'm thinking maybe try Ford Parts from and 86 Ford Dana 44, they used to be 5x5.5 right?
Thanks,
Andrew
mtndew1 is offline
post #9 of 28 Old 08-24-2010, 09:00 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
When it comes to brakes on my CJ's I pull the part and take it with me to match it up. My 80 ended up using front pads off a 95 ford F150
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #10 of 28 Old 08-24-2010, 09:09 PM
Shiftace
1977 CJ5
It sounds like Fords to me but I don't think I've ever come across a 44 rearend in a Ford. Ford did make an 11" drum with 5x5.5 but usually in the dana 60 or Ford 9" rearends. Is there a 60 or 60-2 cast into the housing?
Shiftace is offline
post #11 of 28 Old 08-24-2010, 09:14 PM
Coiz
1979 CJ7
1972-75 CJ5's came with a D44 with 11" drums.
Mike
Coiz is offline
post #12 of 28 Old 08-24-2010, 09:46 PM Thread Starter
mtndew1
1976 CJ7
Yeah I might explore that a bit more but it's for sure not a narrow trac and the 11" drums don't look anything like the ones I think go on the CJ5 D44's. I'll take it apart tomorrow and get some pictures.
Mine don't have fin's like this one but perhaps not all of them did.
mtndew1 is offline
post #13 of 28 Old 08-24-2010, 10:05 PM
Trapshooter
rockauto.com has parts for the 11" drums, look up '86 CJ7 brakes and you'll find what you need.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #14 of 28 Old 08-25-2010, 05:53 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
No chance it's a 58" wide Scout II axle?.. My Scoutt D44 rear has 11 drums that aren't finned.
BESRK is offline
post #15 of 28 Old 08-25-2010, 07:55 AM
CSP
You're correct, not all of them did. My '75 had 3.73 gears originally with the finned drums. I swapped in axles from a '72 which had the 4.27 gears I wanted, but didn't have the finned drums. Of course, I did swap the drums out.
A lot of times the BOM is obscured with paint, grime, etc. I've had to remove all paint in the area with a rotoloc pad on a die grinder to see them sometimes.
CSP is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Dana 30 ->ford 9" or Dana 44 Front Axle Swap smoothop Jeep CJ Forum 9 09-18-2011 09:28 AM
Dana 30 Narrow - Dana 30 Wide swap T3hRustyWalnut Jeep CJ Forum 12 04-23-2009 08:26 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
