CJ Custom Gauges in a Custom dash Need Opinions - JeepForum.com
post #1 of 17 Old 08-26-2009, 07:15 PM Thread Starter
Tigger01
Hi every one
Have a Question
I had Daniel at Double D Fab make me up a Custom Dash Panel
He does make a sweet dash I may add.
The holes cut out in the dash are four 2 1/16 holes for the
Volt,Fuel Temp and Oil ( don't have any problems here )
And two 3 3/8 holes for the Tach and Speedometer
all of the Tach's found will work But its the Speedometer were the Question is
Have been told to get a Mechanical Speedometer due to the Speedometer Cable to the Transfer case
Yes I have found a few that will work through Summit Racing
But nothing has hit me yet I like
The Ones I do like are the Electrical Speedometers in the style I like
Guess my question is what would you have to do to use a Electrical speedometer Rather than a Mechanical Speedometer In my 84 CJ-7 with a 304 V-8
I have been looking for a guages with a white backing, black numbering and lettering , Orange needle and a Chrome bezel
Also What is Every one else using
I have been trying to make an Order for these and keep getting stumped
Thanks
Chris - tigger
Tigger01 is offline
post #2 of 17 Old 08-26-2009, 08:18 PM
cshutchinson
Box Man
cshutchinson's Avatar
Check out this thread, as the same thing was done and you can see the results:
http://www.jeepforum.com/forum/f8/pr...0/index11.html
1985 CJ7 / SBC 383 / D300 / NV3550 / 35 SSRs
cshutchinson is offline
post #3 of 17 Old 08-26-2009, 09:12 PM
xbarksdale
1980 CJ7
awesome thread!
xbarksdale is offline
post #4 of 17 Old 08-27-2009, 08:48 AM
Gunga
1978 CJ7
I like Autometer. I think they have the biggest selection too.
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #5 of 17 Old 02-25-2011, 10:00 PM
boomvader
Originally Posted by Tigger01 View Post
Hi every one
Have a Question
Thanks
Chris - tigger
Chris, were you able to go electric on the speedometer? If so, what did you need to do and/or buy?
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #6 of 17 Old 02-26-2011, 06:13 PM Thread Starter
Tigger01
No we went manual on the speedo ,temp, and Oil but think the fuel, Tac, and volt might be electric
Don't Know if the web site will work off my wish List from summit Racing but here is what I ordered
http://www.summitracing.com/myaccount/wishlist.aspx
Chris-Tigger
Tigger01 is offline
post #7 of 17 Old 02-26-2011, 06:15 PM
benullman
1981 CJ7
Chris-Tigger
nope doesnt work. Get the part #
Ben-Junior
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #8 of 17 Old 02-26-2011, 06:28 PM
boomvader
I am trying to find out if the Autometer electronic sending unit is compatible with the Dana 300 tc.
-boom
post #9 of 17 Old 02-26-2011, 06:30 PM Thread Starter
Tigger01
Tigger01 is offline
post #10 of 17 Old 02-26-2011, 07:01 PM Thread Starter
Tigger01
Sorry guess your question was:
Answer: I don't think you will be able to use Electronic to the Dana 300 TC you have to have the Cable that hooks into the TC then runs to the Seedo in the dash.
I ordered a new cable through 4wd hardware on mine
But the link above is the gauges I ordered for mine
Hope this helps
Chris-tigger
Tigger01 is offline
post #11 of 17 Old 02-26-2011, 07:17 PM
james04si
james04si's Avatar
1977 CJ5
I have the model 20 tc and the speedo cable goes to it. yes you can use an electronic speedometer. you just connect the sensor at the transfer case and wire it up to the new speedo and calibrate the speedometer for the correct pulse per mile(autometer you drive 2 miles to program). the good thing about an electronic speedometer is that you never have to worry about changing the speedometer gear in the transfer case again if you change tire sizes. you just reprogram the speedo for the new pulse per mile. I used the generic summit racing speed sensor with my autometer gauges. previously I used an intelletronics speed sensor with my intelletronics digital gauges.
james04si is offline
post #12 of 17 Old 02-26-2011, 07:48 PM Thread Starter
Tigger01
Good to know
Thanks James04si
I really did not know the answer all I could go off of is what I did
Tigger01 is offline
post #13 of 17 Old 02-26-2011, 08:00 PM
boomvader
Thanks, guys!
James: Do you have a part number for the Summit racing speed sensor?
-boom
post #14 of 17 Old 02-26-2011, 08:51 PM
james04si
james04si's Avatar
1977 CJ5
I picked up this one that is no longer carried.
http://www.summitracing.com/parts/NRD-S9013/
But really if you get a autometer electronic speedometer any made for a GM with a 7/8 - 18 thread size will work.The autometer gauges accept the signal from a 2 wire sine wave or a 3 wire square wave/hall effect sensor. Here is a link to the one made by autometer that works on the jeep.
http://www.summitracing.com/parts/ATM-5291/
and here is the summit generic one that will work as well
http://www.summitracing.com/parts/SUM-G2887-1/
post #15 of 17 Old 02-26-2011, 10:41 PM
boomvader
James/Chris... Many thanks guys! I am about to order my gauges and have been racking my brain to try and find this answer. Much appreciated!!
-boom
Show off your custom dash! 78CJFIVE Jeep CJ Forum 6 11-17-2008 10:06 PM
custom dash vtjeeps Jeep CJ Forum 13 01-19-2008 11:04 PM
My soon to be custom dash. bulljeeper Jeep CJ Forum 20 08-28-2007 10:12 AM
Custom Dash napoleoneight Jeep CJ Forum 32 02-26-2007 06:26 PM
Custom Dash 79 CJ7 Jeep CJ Forum 21 07-25-2006 11:53 PM
