CJ Coolant Overflow Bottle - repair or replace? - JeepForum.com
post #1 of 7 Old 09-07-2011, 02:31 PM Thread Starter
N7TX
I'm the orig owner of my '84 CJ-7. The stock overflow bottle lasted nearly 20 yrs - it finally cracked and I replaced it. I've now gone thru two "OEM replacement" (aftermarket) bottles, and both have cracked after not a whole lot of use.
I could attempt to repair the crack in the plastic, or could buy yet another OEM replacement, but I'm thinking it may be best to go with something else altogether. An aluminum bottle would be nice, but then it may not be easy to see the coolant level.
For those who have had issues with repeatedly replacing these cheap aftermarket bottles, what better solution have you found?
If you've repaired the plastic, how did you repair the plastic?
Thanks
Steve Thompson
Cave Creek, Arizona
'84 CJ-7
N7TX is offline
post #2 of 7 Old 09-07-2011, 02:44 PM
CGrugger
CGrugger's Avatar
I just use a coke bottle. it has been working for about 6 years now...
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #3 of 7 Old 09-07-2011, 03:25 PM
scrapman
Mine hasn't had one since I bought it 2 years ago. Runs fine, no overheating.
scrapman is offline
post #4 of 7 Old 09-07-2011, 03:51 PM
Astrodokk
Location: Sonoma County, an hour north of San Francisco in wine country.
Mine didn't have the lid and was empty when I bought it. I finally found a lid that fits from Oreily but I forgot to fill the bottle. It hasn't needed it and runs cool. But I will fill it soon just in case. My old timer retired mechanic friend told me that I didn't need one and to just check the radiator level when cold every once in awhile like in the old days. I'm lazy though.
2000 Jeep WJ Grand Cherokee Limited, Black/Black, 4.7L
Astrodokk is offline
post #5 of 7 Old 09-07-2011, 04:21 PM
CSP
My CJ didn't have an overflow bottle from the factory. I found one in a junkyard that would work. I can't remember what I pulled it out of.
CSP is offline
post #6 of 7 Old 09-07-2011, 05:58 PM
wellmax
both the radiator overflow bottle and windshield washer bottle on my 1984 jeep were cracked.
i tried to repair the radiator overflow bottle, did not work, so it has not had one for years,
but i do check the coolant level from time to time, as the coolant will expand out, the bottle was there to catch the overflow and it was sucked back in when system cooled down. Otherwise the overflow goes out on the ground and you lose it.
check your manual and be sure you have the correct psi radiator cap,
caps do go bad and will not hold the coolant in as the spring gets weak, a new cap is cheap insurance to keep you from losing your coolant..
wellmax is offline
post #7 of 7 Old 09-07-2011, 06:01 PM
Nereussailor
How about going with something like this? http://shop.advanceautoparts.com/web...7CGRP2014_____
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
1983 CJ7 coolant overflow/recovery bottle cjkcj7 Jeep CJ Forum 16 12-24-2014 06:15 AM
Cooland Overflow Bottle - 84 CJ7 Hibbitz Jeep CJ Forum 9 05-01-2013 08:28 AM
Overflow bottle and washer fluid bottle? spottedfrog Jeep CJ Forum 8 08-21-2011 04:04 PM
Stock locations of washer bottle and overflow bottle? cw4stein Jeep CJ Forum 3 12-23-2009 08:46 PM
overflow bottle CJMONEYPIT Jeep CJ Forum 5 01-10-2003 06:38 PM
