CJ Changes & Specs by the year - JeepForum.com
post #1 of 13 Old 11-13-2011, 06:22 PM Thread Starter
rocketfuel
Anyone know where I can find a list of changes from year to year betwen year models?
i.e difference between an 81 cj7, 82 cj7 83cj7
In addition I'm looking at a 82 CJ7 Renegade almost all original any constructive thoughts or comments?
Thanks! Excited this could be my first cj7 !
rocketfuel is offline
post #2 of 13 Old 11-13-2011, 06:25 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Do you have more info on the '82...ie eng/trans+condition & $$ etc..
hutch1200 is offline
post #3 of 13 Old 11-13-2011, 06:27 PM Thread Starter
rocketfuel
258 6cyl & 4spd just about rust free
That was a fast reply, thanks
still looking for changes year by year surprised it's so hard to find my google fu must be weak
post #4 of 13 Old 11-13-2011, 06:34 PM
DirtyDevin
1983 CJ7
The 82 and up had wide track axles, which is a very good thing. Other than that a solid rust free body and frame is what you want.
DirtyDevin is offline
post #5 of 13 Old 11-13-2011, 07:07 PM
BagusJeep
1981 CJ7
There numerous part changes between the 1981-1982 models and the 1983-86 models, but you need to have a parts manual to identify them as such.
For instance the exterior decals changed for 1983-1985 on a Renegade from the 1981-1982 scheme so this is one external reference which COULD identify the model year, but it is just a sticker than any bozo could put on. They introduced a side stripe on the tub and the bonnet stripes were now in a small U in the dead centre of the bonnet (hood) instead of around the edge.
The substantive changes were in the engine compartment and drive train. The emissions controls etc. were beefed up but then they were under constant change from 1981 to 1985. The most obvious change was to introduce a wider track on the axles from 1982 as mentioned above and a large number were fitted with dana 44 rear axles as the AMC20 supply dried up, supposedly only in 1986 but some were fitted earlier apparently.
PICTURES, PICTURES, PICTURES.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 13 Old 11-13-2011, 07:22 PM Thread Starter
rocketfuel
dana 44 is what i'd want it to have right? any way to tell what is has from vin or getting a pic of the rear?
Thanks
might post pics soon i dont want it bought out from under me though lol
post #7 of 13 Old 11-13-2011, 08:38 PM
BagusJeep
1981 CJ7
A Dana 44 is a mildly better axle but not a deal breaker.
You can tell from the diff cover, a round hemisphere is an AMC20, one with a rectangular vertical lump sticking out is probably a Dana 44.
post #8 of 13 Old 11-13-2011, 09:32 PM
keith460
Jeep. There's Only One
keith460's Avatar
You won't find a D44 rear axle in 1982 unless someone swapped it out. AMC20 more than likely.
To learn some info on what was available year-to-year, try to find original Jeep sales brochures on the internet.
Like this one: http://oljeep.com/edge_82_brochure.html
1984 CJ-7 Renegade
keith460 is offline
post #9 of 13 Old 11-13-2011, 10:07 PM Thread Starter
rocketfuel
wow that's so cool!! Thanks for sharing that
post #10 of 13 Old 11-14-2011, 08:58 AM
dirtman13
dirtman13's Avatar
2007 CJ7
dirtman13 is offline
post #11 of 13 Old 11-14-2011, 09:18 AM
Renegade82
1982 CJ7
This may help too, at least with the Renegade decal ID.
http://www.jeepfan.com/tech/cj-renegade-spotters-guide/
This will help with the axles.
http://www.jeepfan.com/tech/jeep-axles-spotters-guide/
And this for some misc. stuff.
http://www.jeepfan.com/tech/jeep-spotters-guide-part-2/
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #12 of 13 Old 11-14-2011, 12:04 PM
7179CJ5
1979 CJ5
i tell you, this forum is GREAT!! if you want to find out anything about jeeps, just ask. somebody out there will have the answer or point you in the right direction to find it.
7179CJ5 is offline
post #13 of 13 Old 11-16-2011, 04:09 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
I think one major change for the CJ's was the impact of the EPA standards.
That standard dictated a mileage per gallon minimums and created the usage of some crappy gearing such as the 3.07 gear sets, SMOG equipment and for the 304 V8, it also meant reducing the HP on a regular basis in accordance to the following (per wikipedia)
"...The 304 had a displacement of 303.92 CID (4,980.3 cc) which produced 210 hp (157 kW) in 1970-71 and was built starting in 1970.
Later models produced less power from the factory, going down yearly.
1972-78 models were rated at 150 hp (112 kW).
It was rated at 130 hp (97 kW) in 1979, the last year it was installed in passenger cars, and 125 hp (93 kW) in 1980-81, the last years it was used in Jeep vehicles."
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
4.2 Liter motor mount bracket to block specs and motor mount nut and 2 bolts specs agear Jeep CJ Forum 4 11-14-2011 03:29 PM
Need year of AMC 360 for timing specs.... Dborns Jeep CJ Forum 5 03-26-2010 07:22 AM
specs on amc 360? 308turbo Jeep CJ Forum 4 03-25-2008 01:23 PM
AMC 318 and 360 specs... vladrulli Jeep CJ Forum 4 05-15-2006 07:03 AM
CAM Specs. centralflaCJ Jeep CJ Forum 4 11-03-2005 03:19 PM
