cj brakes to power brakes worth it? - JeepForum.com
post #1 of 22 Old 02-13-2008, 10:17 AM Thread Starter
drunkenrich
1980 CJ7
Is it converting my stock 1980 cj brakes to the newer power brakes with the booster of the yj? how hard is it to do?
drunkenrich is offline
post #2 of 22 Old 02-13-2008, 11:05 AM
Blthomas
Blthomas's Avatar
1979 CJ7
Mine isn't complete, but so far it's been easy.
I got a booster from a 94'ish YJ.
Cut the pushrod, used a tap and die to cut threads on it. No biggie, some cutting oil, did fine. Little tough since the rod is hard, but it worked out with some patience.
The coupler is out of the parts drawer at the hardware store. Still haven't welded mine.
Only four bolts connect it. I have a tubing bender, so I used it to help bend my brake lines around.
The guy I got mine from sold me the fittings for the YJ cylinder to the CJ lines. They fit perfect.
I need to bleed my master, then bolt her up and get her done.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #3 of 22 Old 02-13-2008, 12:40 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Best mod I've done to date.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #4 of 22 Old 02-13-2008, 12:48 PM
Pog
Pog's Avatar
For what it's worth, I'm on my third CJ and my first to have power brakes. It's absolutely worth it and makes a world of difference to me. Especially if you have larger tires. I had to stand on the brakes of my '79 CJ5 and '79 CJ7 to stop sometimes. My '84 CJ7 with PBs works like a dream compared to the earlier two. I cannot speak to the value of you going through the conversion process to PBs but I cannot imagine you being unhappy with it.
Pog is offline
post #5 of 22 Old 02-13-2008, 01:39 PM
jatepper
X2 Very easy to do! Much better stopping power. First time I tested them out my face almost smacked the windshield...poor windshield.
Bought a YJ booster from a salvage yard. Best $80 I have ever spent!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #6 of 22 Old 02-13-2008, 05:40 PM
smokencj7
i put a yj booster on mine and didnt neet to do anything and it will lock all 4 up and it has 33 on it best mod i dont ather then the chevy blower motor
smokencj7 is offline
post #7 of 22 Old 02-13-2008, 06:00 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
since i went to 3/4 ton axles i needed proper stopping power. Getting those Chevy brake calipers to engage takes a lot of oomph! Went with the booster from Harold Off, called the Navajo brake booster. AWESOME! So perhaps consider that rather than the YJ set up. It works better than expected. After the MOPAR EFI kit, this was the 2ed best upgrade.
good luck.
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #8 of 22 Old 02-13-2008, 06:29 PM
John N
1981 CJ8
good luck.
mb
Ditto, I did the same. Amazing difference, I wouldn't go back.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #9 of 22 Old 02-13-2008, 07:00 PM
Rollbar
1984 CJ8
Well I was going to swap but instead I installed a set of NAPA Safety Stop Brake pads/shoes (couldn't get the ones I wanted from O' Riley's quick enough) & turned the rear drums (front disk), installed, adjusted & everything works better than new. I never had brakes work this good on a CJ.
Oh, I forgot to tell U that I have manual MC/brakes on 33's & it locks up the rear & stops very well. IMO, I like the manual brakes for obvious reasons, no motor, still stops, on road/off-road.
<----Click
<---- Click
Rollbar is offline
post #10 of 22 Old 02-13-2008, 07:45 PM Thread Starter
drunkenrich
1980 CJ7
do i need to change the brake lines at all?
post #11 of 22 Old 02-13-2008, 07:50 PM
Rollbar
1984 CJ8
I changed out my 22 yr old brake lines & it did help big time. New wheel cyl & all, the whole works.
<----Click
<---- Click
Rollbar is offline
post #12 of 22 Old 02-13-2008, 08:37 PM
Blthomas
Blthomas's Avatar
1979 CJ7
If they are in decent shape, not IMHO.
Mine are good to go with new stainless extensions, you just need the fitting to go from your CJ line to the hole on the booster.
Even if the guy hadn't sent them I was going to just take the master cylinder down to Napa and figure it out.
The numbers are listed on busted jeep dot com or somewhere for those fittings.
This is a pretty sweet mod from the couple guys I hear I work with that have CJ's and done this.
81' CJ8 bone stock
Blthomas is offline
post #13 of 22 Old 02-13-2008, 09:40 PM
Fjguercio
1978 CJ7
I am spoiled. My 1978 CJ7 came with the big disk brakes front and big drum brakes on the back. I think my CJ came with power brakes and power steering as stock. I can lock them up to stop easy with 33's and jeep stays straight. BUT.... if you jeep stops running on a hill or when you need the brakes you better have strong legs.
HighCountry or MrCrowley also posted that the BRAKE SHOES you use on the CJ make a big difference on the brake performace. Std or Power. I printed and kept the info somewhere for this summer I have to look at the brakes and ck their status. They had one or two they knew worked well. They may post here again or if need I can try to find it. It was posted only a month ago or so.
Can anyone tell me is this the STOCK BRAKE BOOSTER FOR 1978 CJ7??
Fjguercio is offline
post #14 of 22 Old 02-13-2008, 09:47 PM
jeepskate
Yes, that's stock.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #15 of 22 Old 02-14-2008, 09:04 AM
Fjguercio
1978 CJ7
VERY COOL, Thank you for the feedback Jeepskate.
Need opinion....Manual Brakes/360 to Power Brakes Rollbar Jeep CJ Forum 16 04-08-2009 10:06 PM
Manual brakes to power brakes theclothman Jeep CJ Forum 17 06-18-2007 04:40 PM
Manual brakes to power brakes. NOVACAIN350 Jeep CJ Forum 4 04-27-2007 08:16 PM
power brakes? toolmanjim Jeep CJ Forum 22 08-16-2005 10:04 AM
Hydraulic brakes to power brakes question Jeep'N 4 Fun Jeep CJ Forum 5 03-05-2003 10:00 PM
