CJ Bogs Down - JeepForum.com
post #1 of 4 Old 04-14-2011, 08:20 PM Thread Starter
Agggg
CJ Bogs Down
I had my 85 CJ7 (4.2 258) out today and it ran fine. I had recently replaced the water pump and fuel filter. A few times in the past bog down when going up steep hills. It ran perfect all day, but after a bumpy ride in the mountains, it started to bog down. It got really bad when I went back on the highway, going from 2nd to 3rd would feel like it was suffocating. I sprayed out the Weber carburetor, but no luck. This was probably the longest that I have ran her in months, the previous owner had rebuilt the engine and it only has 5000 miles.
Agggg is offline
post #2 of 4 Old 04-14-2011, 08:38 PM
mcmud
1983 CJ8
Welcome to JF.
I have a Weber, actually several. Can you identify which one(s) I have?
Reads as though you are experiencing bowl over fill, or in need of a float adjustment.. if we knew which Weber you have mounted I'm sure that sound suggestions would follow.
mcmud is offline
post #3 of 4 Old 04-14-2011, 09:00 PM
truckshop21
1981 CJ5
i bet you got a hole in and fuel line or its dryed out and cracked and sucking air
truckshop21 is offline
post #4 of 4 Old 04-16-2011, 01:36 AM Thread Starter
Agggg
I couldn't find a model number on the carb, but I think we may have found the problem. The fuel lines do look bad, I just picked up some new hose. A friend messed with it for a while and thinks it is the vacuum advance. I am going to repair/replace that line and see what happens.
Thanks for the help.
Agggg is offline
bog , cj , fuel
Engine bogs down somdfisher Jeep CJ Forum 2 11-14-2010 09:06 PM
CJ7 bogs when in put in gear. wine49 Jeep CJ Forum 1 05-20-2009 03:23 PM
bogs down at 3000 rpms TJTony Jeep CJ Forum 2 08-17-2007 02:17 AM
engine bogs 83 cj-7 258 Jeep CJ Forum 7 06-17-2007 08:58 AM
97 4.0L motor bogs down onesourcemike Jeep CJ Forum 8 05-30-2007 02:45 PM
