CJ ALL OVER THE ROAD - JeepForum.com
post #1 of 14 Old 05-22-2002, 01:49 PM Thread Starter
J.L.Rice
Unhappy CJ ALL OVER THE ROAD
I bought a 75 cj-5 for my boy the other day, and on the way home liked to killed us all. The jeep was all over the road. Anyone have any suggestions on what I need to do to make it anywhere near safe? It felt like everything on the front end was wore out.
J.L.Rice is offline
post #2 of 14 Old 05-22-2002, 02:06 PM
Project CJ7
Post
Does it have oversized tires on it? Maybe get a dual shock steering stabalizer...
'86 CJ7 Project "Bulletproof"
2.5L 4-Banger
Just hit 62,000 miles
Custom Exhaust w/ Dynomax Muffler
31x10 Delta AT Tires
Bikini/Windjammer/Tonneu
Project CJ7 is offline
post #3 of 14 Old 05-22-2002, 02:43 PM
nuzzy
Post
Check the steering box where it attaches to the frame. If it has partially broken free or something like that, it could be causing a lot of play in the steering wheel. Also, turn the steering wheel left and right while watching all the steering components. If there is excessive play somewhere, that could cause the all over the road syndrome.
Slaving away at JCR
nuzzy is offline
post #4 of 14 Old 05-22-2002, 02:55 PM
Chris Purdy
Red face
Very scary man!!!! You may want to have a shop give you an estimate.... Find one that does free estimates and then you can decide what to have fixed and what to do yourself.
When I drove my CJ-7 home from purchase I thought "Wow, those rancho-9000's must be blown... this thing is BOUNCY!!" Just to find out when I got home that the driver seat was only held in by the 2 rear bolts.... the rest was rusted out, and it was bouncing all around. I could have fallen right through the floor....
That was the last time I buy a "restored jeep" when its getting dark outside... Newbie mistake...
You may want to check all your ball-ends and bushings as well... if its stock, then they are probably gone.... add all those things up and you get a lot of play...
...Did I have a dream, or did the dream have me?
- RUSH - Nocturne
Chris Purdy is offline
post #5 of 14 Old 05-22-2002, 06:58 PM
CJ Lover
Post
My 85 CJ-7 did the same thing last year. I replaced the steering box with an AGR High Performance box, best thing I ever did. I also put on a Borguesson steering shaft, that was a great choice too. Check your U-joints and tie rod ends. I did all this and it steered tighter than a new one.
85 CJ-7. 79 vette 350 conversion. 4.56 gears. Lockers. 4" Explorer Pro Comp suspension, 3" body lift. 38" Super Swamper TSL's. Looking to go SOA and take off the body lift.
CJ Lover is offline
post #6 of 14 Old 05-22-2002, 07:24 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
A VERY common cause for your Jeep's problem is bad ball joints - this is especially true considering the age of the vehicle.
Steve
OldJeepguy is offline
post #7 of 14 Old 05-22-2002, 11:57 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
You need to give us the year and model of your Jeep. Also, do you know if the suspension is stock. Ther are many things that effect steering, if you can give us some info perhaps we can help you better.
bazinga
jeepdaddy2000 is offline
post #8 of 14 Old 05-23-2002, 01:24 AM
Hippo393
Smile
Hey Jeepdad, he said it was a 75 CJ-5. <img border="0" title="" alt="[Wink]" src="wink.gif" />
How mechanically inclined are you? Is this the family household's first Jeep? Please give us more details. Was it all over the road at some MPH or all MPH? Many times worn out steering will manifest itself at higher speeds. And sometimes, steering turns out to be the normal wander and it's just part-n-parcel to owning a Jeep. Remember, it's not a minivan!
Maybe if you could take some pictures and post them for us here to see, we could advise further. Particularly if you could snap a shot or two under the front end. It'd be like havin' us there to advise!
Hippo393 is offline
post #9 of 14 Old 05-23-2002, 09:13 AM
Bulletproofcj7
Post
Have some one sit in the drivers seat and turn the wheel back and forth while you watch all of the components from the front. look to see if there is a dead spot in the steering,(the steering wheel turns a little bit but nothing is turning up front) could be a sloppy lower steering shaft going in to the steering box or the box may need adjustment. Next while your friend is still turning the wheel back and forth (only a little bit is needed) grab the tie rod ends and look and feel for any play, there are four of them. also make sure the steering box mounting bolts are tight, and the U-bolts that hold the axle to the springs are tight, front AND rear. the ball joints can be checked by jacking up the front tire off the ground and prying the wheel up with a long bar and checking for play ( perhaps someone else can explain this part in more detail, hard for me to explain)last thing i can think of right now is to check your axle U-joints they should be nice and free, however i dont know of a way to check them with out taking them out( refer to your shop manual if you have one, its not hard) they dont need to be engaged for them to be a problem either as they will not allow the wheels to self center if they are bound up.
Hope this helps, keep us posted as to what you find. I'm curious as to what the problem is.
jason
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #10 of 14 Old 05-23-2002, 09:19 AM Thread Starter
J.L.Rice
Post
THANKS FOR ALL THE INPUT. LIKE I SAID IT'S A STOCK 75 CJ-5. LOOKS LIKE EVERYTHING IS STOCK AND ORIGIONAL IN THE FRONT. I HAVE OWNED SEVERAL JEEPS OVER THE YEARS AND I REMEMBER HOW THEY WERE ON THE ROAD. I GUESS I WANT TO GET IT FIXED AS CHEAP AS POSSIBLE, DON'T WANT TO PUT A LOT OF MONEY IN THIS ONE, JUST HAD A CHOICE OF EITHER A 4 WHEELER OR A JEEP FOR MY 12 YEAR OLD, CHOSE THE JEEP.HE WILL BE RIDING IT ON THE FARM ONLY, BUT ALL THE SHIMMY, POPPING AND CRACKING IS WORRING US.
J.L.Rice is offline
post #11 of 14 Old 05-23-2002, 12:09 PM
GroundUpCJ7
Post
You'd be amazed at how much replacing all the rubber bushings with polyurethane will tighten up a Jeep. It does, however, sound more like you have a bad steering box, or bad ball joints. Neither of which is too difficult to replace, but you'll be spending a little money if you have someone else do it. It probably would not be a bad idea to replace the ball joints first (about $60 total for both sides), since they are most likely old and shot anyway. If that doesn't fix the problem, look for a steering box on ebay or the bulletin boards, and see if that helps out.
Good Luck. I say start em on Jeeps young, that way they have a lifetime of wealth to sink into their vehicle...I'm still catching up.
It's not so much a labor of love as it is shear determination.
GroundUpCJ7 is offline
post #12 of 14 Old 05-23-2002, 03:19 PM
ooze
Post
When i was about your son's age (a little younger)
my dad got an old scooter and a car called a Vuaxhal&lt;sp? both were German. Nethier one ran but me and my buddies had a ball with 'em anyway.
I'll bet your son is in hog heaven.
ooze is offline
post #13 of 14 Old 05-24-2002, 12:40 AM
Hippo393
Post
Jeep for your 12 year old?!?!? Gee, I wish I could be a dad like that!
He'll turn into Popeye trying to keep it between the corn rows. Oh, and teach him to drive with the thumbs out. What are the chances of driving at high speed at the farm anyway? How about posting some pics for us to see/view/drool over?
Parts for the steering, if necessary, should be simple to find and cheap. Let us know if you need resources.
Hippo393 is offline
post #14 of 14 Old 05-25-2002, 06:54 AM
Bummy
Post
Had the same problem with my CJ- ended up replacing the lower steering shaft, adjusting out the "worm gear" in the steering box, and replacing bushings...also adding a steering stabilizer helps tremendously....
'82 CJ-7- 33X12.50, Juicebox Upgrade, and badly in need of some new suspension goodies!!
"You hold it while I hit it...."
Bummy is offline
New guy trying to get a CJ7 on the road... CJ7Pete Jeep CJ Forum 7 07-30-2009 07:42 PM
What's Your CJ look like Off-Road? BigTorqueCJ Jeep CJ Forum 43 04-15-2008 12:40 PM
serious off road use? I think not Bockwinkle Jeep CJ Forum 7 11-25-2006 12:45 PM
On the road again... luficer Jeep CJ Forum 1 09-18-2006 10:17 PM
CJ7 is all over the road disarray0019 Jeep CJ Forum 12 06-10-2005 01:59 PM
