cj 700r4 install with dana 300 - JeepForum.com
post #1 of 3 Old 11-28-2005, 09:23 PM Thread Starter
emjeeper
has anyone ever done this and if you have can you send me a pic of the tranny mont. i need to know how to do this. any help would be great
emjeeper is offline
post #2 of 3 Old 11-29-2005, 05:10 AM
Bard
Hi, I did this about 8 years ago. No pics though. We used a piece of 1 1/2 " square steel tubing and drilled holes to where it bolts up to the tranny from the skid plate. We may have boxed it as well. We also had dropped the skid plate down a inch. Not sure how you mounted it to the Dana 300, Advanced Adapters has a great set up. I swapped mine over to a NP208. Made it all Chevy and the drive shafts had to be made for it. Good luck
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 3 Old 11-29-2005, 09:33 AM
TrailCJ7
TrailCJ7's Avatar
I bought the adapter and the mount from novak their adapter has holes drilled and tapped for the stock jeep transmission mount
TrailCJ7 is offline
Dana 300 advanced adaptor replace input shaft for 700r4 auto tranny smokedog Jeep CJ Forum 12 07-13-2012 04:43 PM
700r4 to dana 300 pan "modification" mike4089 Jeep CJ Forum 8 03-09-2009 12:28 PM
any tricks on a Lock Right install on a Dana 30 Mr.Crowley Jeep CJ Forum 9 03-31-2007 04:29 PM
Dana 300 Install Problem 84cj7er Jeep CJ Forum 1 05-15-2005 08:51 PM
700R4 and Dana 300 wannachrist Jeep CJ Forum 2 05-24-2004 09:01 PM
