CJ 7 Turn Signals - JeepForum.com
post #1 of 3 Old 08-18-2011, 08:58 AM Thread Starter
BEACHCJ7
CJ 7 Turn Signals
I have recently purchased an 1985 CJ7 and have been going through and making sure all the drivetrain and other items are working properly. I am down to the lights and turn signals and have run into a problem. The PO had the drivers side front turn signal unplugged. I went to wire it up green to green and white to white and it has effected the other turn signals as in the lights will come on but not blink, or the driver side light is always on . The PO has also installed some fog lights that are powered off the white to the turn signal, is this my problem? When I pull the light switch out one notch the fog lights come on and when I pull it out all the way the headlights come on. I have looked for a more detailed wiring diagram than what I have in my Haynes manual but I cannot seam to find it. Any suggestions?
BEACHCJ7 is offline
post #2 of 3 Old 08-18-2011, 09:21 AM
gosupes
Get the fog lights off the circuit to start with. The flasher needs a certain amount of current to flex the bi-metal strip to blink the lights. When the PO wired the fog lights in that circuit, he added resistance and changed the current needed by the flasher.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 3 Old 08-20-2011, 08:42 PM
james04si
james04si's Avatar
1977 CJ5
The white has power when the lights are on and probably are not the issue though its not good to be on the original wiring as it was not designed for the additional load. The issue is probably with the front turn signal lamp in the grill. Make sure it is grounded correctly. I had a similar issue and ended up replacing the turn signal as mine was completely rusted and corroded.
james04si is offline
fog light , turn signal , wiring diagram
cj turn signals 00jeepoff Jeep CJ Forum 8 05-20-2011 07:55 AM
cj5 turn signals? rd3cj5 Jeep CJ Forum 4 04-20-2009 03:32 PM
turn signals flashfludjr Jeep CJ Forum 5 03-23-2009 01:01 PM
Turn signals turn on but dont blink JDGordon Jeep CJ Forum 6 02-27-2006 05:17 PM
No turn signals twmattox Jeep CJ Forum 7 12-09-2003 07:03 AM
