cj 7 tub repair/replacement - JeepForum.com
post #1 of 5 Old 09-08-2002, 10:36 PM Thread Starter
Southern Comfort
have recently picked up a 79 cj-7--mechanically sound, but the body is in horrible shape--am toying with the idea o f putting a new tub on it--was wondering if anybody out here could lend some info/pros & cons to the glass tubs as opposed to the metal--any links to this information as well as cost comparison, helpful hints, and any advice would be much appreciated--
bear in mind that i live in the coast in the south, so the vehicles main duty will be playing at the beach, and the occasional mud run--it will probaly never see any rock crawling or any real extreme off road use--
thanks in advance--
Southern Comfort is offline
post #2 of 5 Old 09-09-2002, 09:15 AM
boredstiff
body replacement
I have a glass body on now, and I'm not sure if I would do it again. For one, you have to run many ground lines to different areas due to the fact that you have no body ground now. This happens in the front grill, dash board area, and any other in cab areas and under hood for that matter. It is hard mounting the seat belt anchors too. Not alot of support from the body... would be nice to have a steel floor pan. The pro is no rust, and it's light as hell. I float on the mud as compared to sinking... I don't know, kinda a toss up...
boredstiff is offline
post #3 of 5 Old 09-09-2002, 04:14 PM Thread Starter
Southern Comfort
john---where did you pick up your body from? i am leaning towards the fiberglass body due to living at the beach--was the install fairly simple--was it precut or did you have to blast all of your holes for the firewall, gauges, shifters etc--
thanks for the info
post #4 of 5 Old 09-10-2002, 07:04 AM
boredstiff
Mine was not precut, it did come from 4WD hardware. That was actually what took the most time. In addition, I had to weld a plate of steel across the rear middle body mounts, for some reason the fiberglass body has the mounts in a different area. I have seen that on two rebuilds now. Maybe it's different now, but as of 1 1/2 years ago it wasn't. Feel free to drop me a line at hvnfunru@hotmail.com if you want. Hope everything goes smoothly!
John
post #5 of 5 Old 09-10-2002, 01:15 PM
GroundUpCJ7
Keep an eye on Ebay, people tend to give up on projects, or buy spare Jeeps and sell the parts. You may want to consider a YJ tub. I have a 1980 CJ that had a POS body on it. I've bought a 91 YJ tub to go on it because it's galvanized! That goes nicely with the new galvanized frame that I bought, and axles, and transmission. Guess I don't really have a 1980 anymore LOL...
It's not so much a labor of love as it is shear determination.
GroundUpCJ7 is offline
Best Top repair moparguyrjr Jeep CJ Forum 5 12-03-2009 12:55 PM
CJ Repair in NJ lbijeep Jeep CJ Forum 9 06-17-2009 08:29 AM
Tub repair zappuh Jeep CJ Forum 5 03-26-2009 09:56 PM
How would you repair this? crawdad Jeep CJ Forum 10 04-28-2008 07:30 PM
CJ5 tub repair HELP!!! imaldini Jeep CJ Forum 4 05-01-2007 05:45 PM
