CJ 7 Steering "body roll?" - Page 2 - JeepForum.com
post #16 of 22 Old 07-03-2013, 07:32 PM
skizriz
1978 CJ7
A sway bar is pretty easy to add. I picked one up from Craigslist for about $40, put on new bushings, and bolted it on.
While mine is far from undriveable with the sway bar unhooked, it does make a big difference. I wheel a few miles from home, and often leave it unhooked for the drive home because every thing is covered in mud. It does fine as long as you are careful.
I sure wouldn't drive it like that for the 200+ miles a week that I spend DD'ing it on back roads, highway speeds, zipping in and out of traffic, etc....
skizriz is online now
post #17 of 22 Old 07-06-2013, 09:40 AM Thread Starter
chrisfuel
ok here is what I have found out: the shackles that came with the OME springs are made by others. The front shackles are 3 1/2" center of bolt to center of bolt, the rear are 4 1/2". The shackles are two piece and it looks like I am getting about a 1/4" + lean in the back. Question: should I weld a plate in between the shackle sides to firm them up? Do this first before I look at installing another sway bar? thanks for your help!
chrisfuel is offline
post #18 of 22 Old 07-07-2013, 11:14 AM
82JeepCJ7
1982 CJ7
Nope, welding in a bar will do nothing to help with body roll etc.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #19 of 22 Old 07-07-2013, 12:28 PM
jeep_boy02
1980 CJ7
have had SOA driven on street frequently for past 12 years without swaybar... just swapped in YJ leaves and will be going back to using a swaybar... did your kit come with shocks? worn out shocks can make the ride seem very off. My lift is a custom done SOA with around 5.5 inches of lift with stock leaves, never felt dangerous to drive, your SUA 4 inch should be even better on street so there is something going on, I had 4.5 inch long shackles without a brace before and now have MORE shackles which are same length but thicker material and a brace so your shackles should be ok.
jeep_boy02 is offline
post #20 of 22 Old 07-07-2013, 06:26 PM Thread Starter
chrisfuel
yes the kit came with new shocks. wondering if I need to increase the castor. I think I have # 3 shims in there now. Will #4+ help with the steering and ship-saw issues? Kind of like putting longer forks on a bike..
post #21 of 22 Old 07-07-2013, 08:27 PM
skizriz
1978 CJ7
It only takes literally seconds to measure your caster. It will save a lot of time and money over guessing what shims to throw at it.
You're on the correct path with the bike forks analogy. Think of the slower steering of a raked out chopper, compared to the nearly straight up and down forks of a quick turning sport bike.
post #22 of 22 Old 07-12-2013, 12:47 PM Thread Starter
chrisfuel
thanks all!
