CJ-7 stalls when braking - Page 2 - JeepForum.com
post #16 of 23 Old 10-12-2008, 12:48 PM
foggybottombob
If you have a Carter BBD. Get a rebuild kit for $30 or less and rebuild the carb. You will be glad you did. My BBD has had idle and die at stop problems for years. I rebuilt the carb and it is a new beast now.
foggybottombob is offline
post #17 of 23 Old 10-12-2008, 01:33 PM
Mike Romain
You are so right, it does them wonders.
Figure it this way, every time you need plugs, you are supposed to need a carb kit according to the CJ maintenance schedule.
Mike
Mike Romain is offline
post #18 of 23 Old 03-21-2010, 11:35 AM
lotharofthehill
I just had the same problem in my 84 CJ7 with the 258. I just bought this CJ and it ran well after I tuned it up (cap/rotor, plugs, wires, all filters). But I thought I would seafoam it since I didn't know how well she had been taken care of and cleaned. After seafoaming, she had a really rough low idle and a hiccup when starting off from 1st. I then cleaned the carb in and out, did not remove to clean since I will be buying the32/36 soon. Still had the rough idle. Then I read Mikes post about the EGR valve. Sure enough she was a dirty bird. Took it off and cleaned with carb cleaner. Lots of junk came off the diaphram and piston. Now she idles like a champ. Thanks Mike!! My first post but sure I'll have many more. This site kicks azz.
Lothar
lotharofthehill is offline
post #19 of 23 Old 06-08-2010, 08:04 PM
slime
1983 CJ7
This old post has been very helpful to me and my "new" '83 CJ-7. It ran good but died when coming up to a stop quickly. I bought the rebuild kit for the Carter BBD. It made a huge difference. Now, when the brakes are applied I still notice the engine RPM being pulled down, the harder the brakes are applied the more the pull on the engine, but it isn't nearly as bad as it was. I think I need to keep looking at vacuum lines, etc. to really clear up that problem.
slime is offline
post #20 of 23 Old 06-09-2010, 06:18 AM
Mike Romain
Check the intake manifold bolts also. they are notorious for coming loose causing some symptoms like that. Just cleaning the EGR valve with carb cleaner can also fix it if there is carbon in the valve.
Mike
post #21 of 23 Old 06-13-2010, 07:52 PM
lotharofthehill
Check all vacuum lines first. I had a crack on the one running from dizzy to T connector. Changed that and couldn't get it to kill coming to a stop. Before if I coasted to a stop no problems, but once I hit the brakes It would die.
Vacuum hose = $0.49/foot
post #22 of 23 Old 06-13-2013, 10:31 PM
jaw1959
1983 CJ7
Originally Posted by LostINohiO View Post
ok listen:
you have clogged idle jets in your venturi...
the good news:
you can fix this yourself in 20 minutes...
u have to take the air filter off... remove the choke plate rod... remove the choke plate.... unscrew the venturi.... pull it out... try not to mess up the gasket unless u have a spare rebuild kit around...
run carb cleaner and guitar string (i used a "B" string) or piano wire through the idle jets and make sure they are clean clean clean... put it back together and viola!
no more idle problems....
many a person has replaced their carb unecessarily and complained about the BBD w/o ever getting to know a simple simple fix....
try it....
prove me right or wrong....
Ok, listen:
I tried what you describe here (though I found the information on another thread) and nothing was clogged. I did find that the two gaskets in the venturi assembly were reversed, so I corrected that, but I'm still getting the same stalling issue, and it seems to get worse as the engine warms up.
So anyway, it looks like i've proven you wrong, all these years later.
jaw1959 is offline
post #23 of 23 Old 03-22-2014, 06:25 PM
SJMixology
1983 CJ7
I'm finding that my '83 is stalling now when I come to a stop. Sometimes when I put it into reverse or drive after starting the engine and warming up. This is my first 258, will try all of the suggestions I've read above and let you know how it goes!
SJMixology is offline
258 just up and stalls mmerlina Jeep CJ Forum 4 11-22-2009 06:21 AM
258 stalls at 20 mph 80HouLaredo Jeep CJ Forum 3 11-08-2009 01:02 PM
Braking while in 4wd hi CompGuru Jeep CJ Forum 17 12-03-2007 12:05 AM
Stalls when braking matthewdmackey Jeep CJ Forum 8 03-18-2007 08:40 PM
stalls when braking??? famicom21 Jeep CJ Forum 11 04-01-2006 10:48 AM
