CJ-7 restoration advice - JeepForum.com
post #1 of 4 Old 03-11-2002, 09:14 PM Thread Starter
duke
Post CJ-7 restoration advice
I have a 1980 CJ7 w/ a 304 that I am currently restoring. I have blown most of my restoration funds on the engine, suspension, and tires. The body is pretty straight but I have some rust that was hidden by bondo. I need a cheap way to fix this problem for a year or two. Advice welcome
duke is offline
post #2 of 4 Old 03-11-2002, 10:25 PM
only in a jeep cj
Post
If you just want a year or 2, blast out the bondo, and cover the areas with tall rocker panels and rivit in a temp floor pan.......providing your rust is in the common places. In the mean time, scout for a YJ tub or a clean CJ tub.....well worth the swap if you have moocho rusto.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 4 Old 03-12-2002, 10:32 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
I am in a similar situation with my current 77 CJ-7. I am "patching" mine, and I expect to get maybe 5 years out of it for now.
It makes a big difference exactly where your rust is, and if it is rust or rot. Check your Body Mount points, and basically any area that is load-bearing or structural. If it is pretty solid there, then the rest can be successfully patched for a while.
Mine is solid everywhere that counts (Body Mounts, Seat Mounts, Seat Belt Mounts, Spring Hangers, Shackle Mounts, etc.). I need to do lower rockers and a driver's floor pan, as well as new rear corners. Those are relatively easy fixes, if that is like what you have, and worth doing.
4wheeler4CJ is offline
post #4 of 4 Old 03-12-2002, 03:31 PM
SKRMBLRMAN
Post
If your only goal is to pass inspection and you don't care about looks, sheet metal and a pop riveter will solve all but structural problems
SKRMBLRMAN is offline
CJ2a Restoration advice XtreemJeeper Jeep CJ Forum 0 01-29-2010 11:04 AM
CJ Advice for new CJ owner on restoration project? medic0749 Jeep CJ Forum 6 01-24-2010 12:48 PM
Need CJ7 body & frame restoration advice, combining 2 CJ-7s into 1 Denver_Diesel Jeep CJ Forum 5 09-16-2009 08:31 AM
78 CJ7 Restoration advice gonzo73 Jeep CJ Forum 4 10-25-2007 09:27 PM
