CJ-7 Rear Axle - JeepForum.com
post #1 of 5 Old 11-09-2002, 11:53 AM Thread Starter
Deru Sudibyo
1983 CJ7
CJ-7 Rear Axle
Hi Netters,
Here is my 2nd Q.
Compare to my other 4x4's (Toyota LC BJ56 and LR Defender 110 TDI), Jeep CJ-7 is the weakest one. The worse is its rear axle. Although use one-piece shaft, but the construction of bearing housing is still weak. Bearing still works extra, as a bearing and to hold the axle shaft.
I am thinking it will be as strong as BJ56 or 110Tdi if converted to their technology, which is full floating. Is that possible? I have asked to so many Jeep shops in my country, but the answers were impossible. No such part for this conversion. Any one of you have surprise experience to be shared?
Thanks & regards,
Deru
Deru Sudibyo is offline
post #2 of 5 Old 11-09-2002, 03:46 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Warn makes a full-float conversion for the model 20. Most of the bigger Jeep shops sell it. Here is the listing from 4WD Hardware:
http://www.4wd.com/Shop4wd/ProductDe...uctSku=6175365
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 5 Old 11-09-2002, 04:05 PM
rustyCJ
why does everyone knock the amc 20? with one piece axle shafts its a stout axle that is comparible to a D44.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #4 of 5 Old 11-09-2002, 05:11 PM Thread Starter
Deru Sudibyo
1983 CJ7
Huh... really surprise!!! I believe nobody knows in my country. I just visited the site and saw it. Unbelievable thing is such kits also available for Wrangler and Cherokee. How small is it?
Now I am thinking how to get it, since it's not marketed around here. Should I import it directly? Or... maybe I can help Warn as their distributor to sell it in my country.
rgds,
Deru
post #5 of 5 Old 11-10-2002, 11:56 AM
dana60cj
dana60cj's Avatar
That kit has been around for a while and re-designed a few times too. It makes the axle much stronger as the axle only has to bear the load of turning not weight.
The amc20 is a rather stout axle and has a bigger r+p than the 44 too. The shafts are small though and the housing is thin. Other than that it is ok, with a full floater in there it will not be indestructable though it is probably the best axle kit for it.
dana60cj is offline
rear axle leaking on 84 cj7,AMC20 rear end swjohnson5 Jeep CJ Forum 12 11-24-2012 03:03 PM
New Rear Axle goat24 Jeep CJ Forum 4 01-06-2008 01:10 PM
Changing my AMC 20 rear axle....and if I used a Land Rover series III axle? Frankcr Jeep CJ Forum 0 09-15-2007 02:13 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 09:25 PM
