cj-7 overall spring width narrower in rear than front of front axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > cj-7 overall spring width narrower in rear than front of front axle
REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88-2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1990 - 1998 Jeep Cherokee Front Wheel Bearing & Hub As
Unread 11-06-2011, 10:35 AM   #1
ttm
1983 CJ7
thanks I do have another issue, when I mounted the springs to the axle, I had a 1" difference in width front of spring to rear of spring,
IOW's
the rear of the front leaf measures 29 1/16" outside of spring to utside of spring at the rear hanger, the front (after setting the axle down onto the locating pins), at the hanger measures 30" and forces the shackle out at the bottom creating the shackles to point at an angle, it is like the axle dowels are to wide by a half inch or so, my jeep seemed untouched before except for new red poly leaf spring bushings,
so I checked the rear as well and get the same thing, only in reverse, the front of the rear spring is 37 11/16 overall width at the hanger and the rear of the rear springs is 39 11/16 overall width, I'm measuring spring to spring not the bushings, would it be that the bushings should be smaller on one side? of the spring? IOWS one half of the bushing be a 1/4 skinnier than the other half?
Any help would be appreciated!
'83 CJ-7 6cyl, 4 speed manual - as I bought it - http://tinyurl.com/83cj7now
have done a lot of repairs already to her though, (upgrades in progress)
'06 4wd CTD Ram 3500 dually - with 35's - http://tinyurl.com/06ctddually
ttm is offline   Reply With Quote
Unread 11-06-2011, 11:13 AM   #2
gojeepin
gojeepin's Avatar
1983 CJ7
That usually means you connected the springs in this order:
1) at the frame
2) on the axle
3) at the shackle
If you connect them in this order, you can algin the spring on the perches more accurately.
1) at the frame
2) at the shackle
3) on the axle
Vibration? Bump steer? Wandering? Read: Steering, suspension, and driveline basics. An article on how it works and where to look for problems.
83 CJ7, 4.1L 6cyl (4.0L bored .030" over), 35" tires, T-5 transmission, Dana 300 TC, Trussed AMC 20.
gojeepin is offline   Reply With Quote
Unread 11-06-2011, 11:25 AM   #3
ttm
1983 CJ7
1) at the frame
2) on the axle
3) at the shackle
1) at the frame
2) at the shackle
3) on the axle
I connected to fixed frame mount bolts snug not torqued, then shackles, again bolts snug not torqued, then to put set the axle on the pins, I had to spread the sprig slightly,I let it hang before trying to tighten anything, it then coks the shackles outward a the bottom, so I started measuring to find them about 1" wider at the front cocking the shackle
thanks for the help!
Unread 11-06-2011, 11:27 AM   #4
Matt1981CJ7
Lifetime CJ User
Matt1981CJ7's Avatar
1981 CJ7
Mine measure 30" outside to outside on both ends of the front and 38-3/8" on both ends of the back.
Could it be your axles shifted relative to the frame, when you had it apart?
I've found it easiest to attach both ends of the spring loosely, then wrestle the spring perch and centering pin together. Sometimes, compressing the spring with a floor jack, placed to one side or the other of the spring plate, helps as well.
Matt
"I'm pretty sure Jesus drives a CJ. He understands."
Matt1981CJ7 is offline   Reply With Quote
Unread 11-06-2011, 11:32 AM   #5
ttm
1983 CJ7
it would ten be off to one side, the springs are actually closer together in the rear of the spring (fixed frame hanger) than they are in the front (shackle end) by 1" I took a pic of each, you can see right side angled towards right outer of cj, and the left angled out to the left side of cj, I had originally thought I had a bent shackle, but they did it with new shackles as well
Unread 11-06-2011, 11:38 AM   #6
Matt1981CJ7
Lifetime CJ User
1981 CJ7
Since you like to measure things (grin), have you checked your frame dimensions? It could be your frame is tweaked, slightly, causing the problem.
Here's the blueprint.
Matt
Unread 11-06-2011, 11:42 AM   #7
ttm
1983 CJ7
Matt
I'll need a new tape before this is over <g>
I have actually tried to find the width spec for the spring mounts with no luck, thanks for that drawing, I will try to see if I can tell if the fixed mounts are off on it now
Unread 11-06-2011, 11:56 AM   #8
jeepwhore
Originally Posted by ttm View Post
......I have actually tried to find the width spec for the spring mounts with no luck.....
As shown in that drawing, the hangers and shackle mounts for the front axle should be 27.5" apart (center to center) and the rears should be 36". The mounting points should be the same width apart as the center to center measurement of the spring perches of their respective axles (maybe something else to check, perhaps the perch locations are slightly off).
'84 CJ-7: 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, Yukon 1 pc axles, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rear aussie locker, twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote
Unread 11-06-2011, 06:15 PM   #9
ttm
1983 CJ7
Matt
I'll check those measurements 1st thing in the am,
Thanks Matt and everyone else!
Tom
Unread 11-06-2011, 06:17 PM   #10
ttm
1983 CJ7
I will check them 1st thing, I had to take off for a while this evening, and it is flat dark out now
thanks, I'll report what I find in the am
