-   -   cj-7 overall spring width narrower in rear than front of front axle (http://www.jeepforum.com/forum/f8/cj-7-overall-spring-width-narrower-rear-than-front-front-axle-1286013/)
ttm 11-06-2011 10:35 AM
thanks I do have another issue, when I mounted the springs to the axle, I had a 1" difference in width front of spring to rear of spring,
IOW's
the rear of the front leaf measures 29 1/16" outside of spring to utside of spring at the rear hanger, the front (after setting the axle down onto the locating pins), at the hanger measures 30" and forces the shackle out at the bottom creating the shackles to point at an angle, it is like the axle dowels are to wide by a half inch or so, my jeep seemed untouched before except for new red poly leaf spring bushings,
so I checked the rear as well and get the same thing, only in reverse, the front of the rear spring is 37 11/16 overall width at the hanger and the rear of the rear springs is 39 11/16 overall width, I'm measuring spring to spring not the bushings, would it be that the bushings should be smaller on one side? of the spring? IOWS one half of the bushing be a 1/4 skinnier than the other half?
Any help would be appreciated!
gojeepin 11-06-2011 11:13 AM
That usually means you connected the springs in this order:
1) at the frame
2) on the axle
3) at the shackle
If you connect them in this order, you can algin the spring on the perches more accurately.
1) at the frame
2) at the shackle
3) on the axle
ttm 11-06-2011 11:25 AM
1) at the frame
2) on the axle
3) at the shackle
1) at the frame
2) at the shackle
3) on the axle
I connected to fixed frame mount bolts snug not torqued, then shackles, again bolts snug not torqued, then to put set the axle on the pins, I had to spread the sprig slightly,I let it hang before trying to tighten anything, it then coks the shackles outward a the bottom, so I started measuring to find them about 1" wider at the front cocking the shackle
thanks for the help!
Matt1981CJ7 11-06-2011 11:27 AM
Mine measure 30" outside to outside on both ends of the front and 38-3/8" on both ends of the back.
Could it be your axles shifted relative to the frame, when you had it apart?
I've found it easiest to attach both ends of the spring loosely, then wrestle the spring perch and centering pin together. Sometimes, compressing the spring with a floor jack, placed to one side or the other of the spring plate, helps as well.
Matt
ttm 11-06-2011 11:32 AM
it would ten be off to one side, the springs are actually closer together in the rear of the spring (fixed frame hanger) than they are in the front (shackle end) by 1" I took a pic of each, you can see right side angled towards right outer of cj, and the left angled out to the left side of cj, I had originally thought I had a bent shackle, but they did it with new shackles as well
Matt1981CJ7 11-06-2011 11:38 AM
1 Attachment(s)
Since you like to measure things (grin), have you checked your frame dimensions? It could be your frame is tweaked, slightly, causing the problem.
Here's the blueprint.
Matt
ttm 11-06-2011 11:42 AM
Matt
I'll need a new tape before this is over <g>
I have actually tried to find the width spec for the spring mounts with no luck, thanks for that drawing, I will try to see if I can tell if the fixed mounts are off on it now
jeepwhore 11-06-2011 11:56 AM
Originally Posted by ttm (Post 12453780)
......I have actually tried to find the width spec for the spring mounts with no luck.....
As shown in that drawing, the hangers and shackle mounts for the front axle should be 27.5" apart (center to center) and the rears should be 36". The mounting points should be the same width apart as the center to center measurement of the spring perches of their respective axles (maybe something else to check, perhaps the perch locations are slightly off).
ttm 11-06-2011 06:15 PM
Matt
I'll check those measurements 1st thing in the am,
Thanks Matt and everyone else!
Tom
ttm 11-06-2011 06:17 PM
I will check them 1st thing, I had to take off for a while this evening, and it is flat dark out now
thanks, I'll report what I find in the am
The time now is 05:27 AM.
