CJ 7 with Howell EFI problems - Page 2 - JeepForum.com
post #16 of 17 Old 09-27-2011, 01:32 PM
CSP
What capacitor would you have pulled with the ignition module? I'm trying to picture where there's a capacitor in an HEI distributor......
CSP is offline
post #17 of 17 Old 10-01-2011, 10:46 AM Thread Starter
Javaboy
1983 CJ7
I've been at this a couple of days and here is where I am at. I really took a close look at the ignition system and realized I was no longer getting a spark. Again it has a new coil. cap, rotor, plugs, wires, ignition module. I finally pulled the cap to watch the rotor and it was not spinning. Great. Pulled the distributor and found out that the Camshaft gear was worn down to nothing.
Pulled valve cover, head, rockers, push rods, lifters, timing cover, chain, gear, and finally camshaft. Replaced camshaft, and components. Reseached into the cause of the distributor chewing the gear and it seems that it could of been a hardened gear, or maybe the wrong angle of cut. Either way I replaced the distributor with a DUI HEI setup.
Everything is back together. I'm getting good spark right now, but the TBI is dumping fuel even more then before. Before the injectors would spray in a nice cone shape but now it is just pouring in. So, starting over... Ideas? Could this be a ground wire? There was a clump of them stuck together and a few look like a bad connection.
Javaboy is offline
efi , fuel , hei , howell
Howell TBI phil77 Jeep CJ Forum 8 06-18-2011 10:26 PM
Howell Fuel Injection and assorted problems 1963hotrod Jeep CJ Forum 4 06-18-2011 10:21 AM
Howell Throttle body conversion problems KYCJ7 Jeep CJ Forum 9 07-03-2008 03:57 PM
Howell injection problems gt4660 Jeep CJ Forum 10 02-26-2007 07:51 AM
problems with the howell tbi joe johnson Jeep CJ Forum 8 01-07-2005 07:02 AM
