CJ-7 Heater upgrade!!! - JeepForum.com
post #1 of 11 Old 09-22-2005, 05:15 AM Thread Starter
gumby
gumby's Avatar
Thumbs up CJ-7 Heater upgrade!!!
: I just finished my cj-7 heater upgrade. I installed the chevy blazer heater blower. I was suprised how quick and easy the whole thing was. took 2 hours start to finish. 2 frosty adult beverages and one pit stop. the hardest part is making sure you get the right blower motor. it seems that the part numbers for a 73 chevy blazer are interchanable and one of them is 1/2 inch to long. This resulted in several trips around town to find the the right one. but then any time I work on the jeep its a manatory 3 trips tothe parts store Advance auto had it for $19. now when you turn the blower on you MUST wear your seat belt. be warned that thing blows harder then pamala Anderson on video tape.
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
post #2 of 11 Old 09-22-2005, 05:58 AM
dawgates
1980 CJ7
Thanks for the advice, and I would love to see that video.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #3 of 11 Old 09-22-2005, 06:36 AM
gosupes
Happen to have the part number on hand? It's on my list of things to do this winter.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #4 of 11 Old 09-22-2005, 07:31 AM
Jaxx
Agree with "gosupes". How about a part number and store name? Online writeups list different #'s sometimes. Another first hand experience on the correct number would be appreciated.
80' CJ7- AMC 360 riding on 33's (Work in progress)
Jaxx is offline
post #5 of 11 Old 09-22-2005, 07:56 AM
Geer_hed
Geer_hed's Avatar
Clicky
Autozone's PM102A worked for me. The one the writeups call for the most (PM105 IIRC) was on the shelf right next to the 102A. Definitely a difference in the cage shaft length.
The 105 compared to OEM:
Check out this thread for better info on which blowers to avoid...
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #6 of 11 Old 09-22-2005, 10:07 AM
390fastback
390fastback's Avatar
I did this to mine last summer, definilty one of the best, quickest, cheapest upgrades you can do to your CJ!
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #7 of 11 Old 09-22-2005, 11:48 AM
bjf498
bjf498's Avatar
1983 CJ7
i don t mean to hijack but anyone know where to get the cage wheel from? mine broke into 100 tiny parts and i need a new one for winter.
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #8 of 11 Old 09-22-2005, 02:13 PM
Geer_hed
Geer_hed's Avatar
I'm thinking you'll probably have to junk yourself one if no one has a spare laying around. I've never seen them for sale anywhere, but I'm sure someone does somewhere... I took some measurements on mine when I had it out for the swap:
Just about any cage with those approx measurements should work. Now there's the matter of fin direction, but you should be able to make that out with the pieces you have left....
or if not, here's a pic...
Geer_hed is offline
post #9 of 11 Old 09-22-2005, 02:55 PM
coas
Heater Motor & Fan Upgrade
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost.
My esnips folders:
coas is offline
post #10 of 11 Old 09-22-2005, 03:01 PM Thread Starter
gumby
gumby's Avatar
PM102A made by seimens works the pm105A is to long. napa and advance carry both numbers . advance also had a blower motor made by "factory Air" part number 35587 this is the one I used. $19.88 ask for a 1973 chevy blazer blower 2 or 4 wd with air or without just check the box number and the part number on the side of the motor. just in case it got put in the wrong box when someone returned it to the shelf.
get your own model for the video
Robert Frost
gumby is offline
post #11 of 11 Old 09-23-2005, 01:40 AM
bjf498
bjf498's Avatar
1983 CJ7
Originally Posted by coas
thank you gear-head and coas!!!
bjf498 is offline
how do i upgrade my heater? thich Jeep CJ Forum 4 01-19-2008 11:49 AM
Heater Upgrade NWA_CJ7 Jeep CJ Forum 44 01-11-2008 02:35 PM
Heater Craft brand heater upgrade PhatBasturd Jeep CJ Forum 0 12-31-2007 08:50 AM
'76 CJ5 heater upgrade? fearsomfoe Jeep CJ Forum 4 04-22-2007 04:04 AM
77 cj 7 Heater upgrade steve1244 Jeep CJ Forum 5 02-24-2004 05:53 AM
