cj 7 Hazard lights come on when I hit the brake! grr - JeepForum.com
post #1 of 7 Old 08-14-2009, 10:17 PM Thread Starter
Ford_Prefect
Ok, so,
IS there a fuse that I am not seeing or something that controls the turn signals? I now hit the brakes and the lights come on, by that I mean the front turn signals come on solid (not blinking) as do the dash turn lights (again not blinking)
Any ideas where I should start on that.
Recent work... I recently swapped out the headlight dimmer switch, but I had no problems with that (in so far as I know) for a week before this happened, so I am thinking they are unrelated.
More info...
The jeep is an 84 cj7 with a 258 5spd
Thanks yall. I could not find a fuse that has been labled turn signal, is there one that I am missing? If so, where would it be located on the fuse box?
Thanks yall
Brian
If you can read this thank a teacher; if you can read it in English, thank an Airman, Sailor, Soldier or Marine
Ford_Prefect is offline
post #2 of 7 Old 08-15-2009, 04:40 AM
Mike Romain
I would be checking the rear bulbs out. A blown one can cause your symptoms. They can also have the glass fall out and short causing the same thing.
Do all the signals work? if one corner doesn't or is dimmer I would start there.
Mike
Mike Romain is offline
post #3 of 7 Old 08-15-2009, 05:13 AM
fish1erp
1982 CJ8
Try the flasher, it happened to me. I think the turn signal is labeled on the box. Fuse No. 15. Try this:
Full-time Firefighter/Paramedic. IAFF Local 2915
"Chrome don't get you home"
fish1erp is offline
post #4 of 7 Old 08-15-2009, 08:20 AM Thread Starter
Ford_Prefect
Thanks.
On the photo above, mine has only ever had one of the very large round ones. (I have had the jeep for six years now) Is that something that I should have on mine as well?
Thanks for the photo, I do not have a flash light, nor a fuse puller, so knowing which one to pull will help a lot!
I guess I can also see if the auto shop can check out the big round one for me too... If that does not fix it then I will look into the tail lights. The reason I put that last is because the last time I had a tail light out it did not react this way.
When I just turn on the turn signals (without touching the brakes) nothing happens at all right now.
Thanks yall!
post #5 of 7 Old 08-15-2009, 10:09 AM
jhagerman
1976 CJ7
I had this issue with my CJ7. In my case it turned out that the hazard switch was pushed in on my steering column (hazards weren't functioning and still aren't), so the brake light switch was feeding power back through the hazard circuit, and illuminating the front turn signals. This may not be your problem, but I thought I would mention it.
jhagerman is offline
post #6 of 7 Old 08-15-2009, 02:08 PM Thread Starter
Ford_Prefect
Thanks yall. Yeah I swapped out the fuse, and that did not do the trick, but the large round one was in the turn signal spot, and I moved it over to the hazzard spot and suddenly everything started working... sigh, such is life.
Thanks again everyone!
Brian
post #7 of 7 Old 08-16-2009, 02:58 PM
John Strenk
John Strenk's Avatar
1976 CJ5
In 84 the TS flasher is under the dash by the parking brake. that socket usually stays empty.
John Strenk is offline
parking lights behaving brake lights, wtf? NJCJ7 Jeep CJ Forum 6 06-04-2010 04:40 PM
D-side brake and hazard light not working but blinkers do Johnyakimo1855 Jeep CJ Forum 0 12-12-2009 10:01 AM
Brake lights/Backup lights issue montypyfly Jeep CJ Forum 3 12-03-2009 05:20 PM
Electrical - Hazard Lights Not Working CJfive Jeep CJ Forum 3 07-03-2008 02:22 AM
brake lights dont work w/ head lights on mike norman Jeep CJ Forum 4 09-27-2005 02:53 PM
