CJ-7 Electrical #@$*##@*!!! - JeepForum.com
post #1 of 3 Old 06-18-2003, 10:49 AM Thread Starter
jddausch
I'm sure this is a problem all of you cj guys have had at one time or an other. Some of the dash panel lights/gauges work periodically, some don't. I'm sure i have a bad ground somewhere, does anyone have any advice as far as an easier way to locate a bad ground than randomly following wires? (which is the way i've gone about it so far). i've had some success so far, but still have gremlins in there somewhere.
Any advice would be appreciated, thanks.
'91 YJ 4 banger
'94 YJ 4.0L
'84 CJ7 258 I6
'12 JK Sahara
jddausch is offline
post #2 of 3 Old 06-18-2003, 04:18 PM
jadams68
jadams68's Avatar
the lights only work if they ground properly in the gauges themselves.
if you are referring to the square indicator lamps, just buy a new set and replace them all...
if you are talking about the lights in the fuel, temp, oil, and volt gauges, reach your hand behind the dash and reset them more snug into the holes they sit in. They have thin prongs on the end that you can bend out to get a snug fit.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 3 Old 06-18-2003, 08:10 PM
Lightningdon
Lightningdon's Avatar
Try pulling the bulb and socket out of each guage and all out of the speedo. You may need to clean up the metal sockets for a good ground. I did this on my '75. You wouldn't believe how corroded they were. Pulled all out and filed the fingers on the sockets where they plug into the guages, then pulled the bulbs and cleaned the contacts inside. Wouldn't hurt to clean the base of each bulb while you're at it. If, by chance you have a F/G body, you may have bad ground on your dash panel itself. Test by running a wire from the panel to a known good ground. If the lites work, that's your prob. If not, keep looking!
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
Electrical help! trueprimitive Jeep CJ Forum 6 08-04-2009 07:15 AM
electrical help jlynch Jeep CJ Forum 6 03-10-2006 11:33 AM
85 CJ7 Electrical TomasPrimero Jeep CJ Forum 6 01-13-2006 11:50 AM
Need Electrical help! mideerhunter Jeep CJ Forum 6 12-18-2005 05:14 PM
Something electrical John C Jeep CJ Forum 0 04-04-2004 08:29 PM
