CJ-7 Drivetrain - JeepForum.com
post #1 of 17 Old 01-04-2006, 08:21 AM Thread Starter
Big_Black_YJ
Big_Black_YJ's Avatar
CJ-7 Drivetrain
just curious, as i don't know much about CJ's
there's a CJ-7 at my local junkyard with a 258 motor that they claim shot a rod.
I'm just wondering what model tranny or tranny's came with them...cuz i'll probably end up buying it if you guys tell me it's worth it.
Either i'll restore it, or swap the drivetrain into my YJ depending on which is in better shape!
thanks in advance!
Black Jeep Club V2.0 Member #89
New England Jeep Club Member #5
The Official I Own a Toy Jeep Club Member #5
Swamp Donkey 4x4
1994 Saab Aero
*MAPTUN STAGE 7, *3" JT Exhaust, *SQR intake
470HP...1/4 mile ET: 12.67 @116MPH
Big_Black_YJ is offline
post #2 of 17 Old 01-04-2006, 08:24 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You can check here for year and model "Stuff" and some pictures of each
http://www.off-road.com/jeep/swb/articles/specgrid.htm
John Strenk is offline
post #3 of 17 Old 01-04-2006, 08:29 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
It depends on the year really, do you know more information about the Jeep? If you are going to get it, make sure to see how the body and frame is or you might end up chasing your tail to get all that fixed prior to getting the engine to run or replacing the engine.
jeeptech.com has some info on the engines/trannies, etc. that came with the Jeeps. Find out what year it is.
Also, if you need another motor, there are usually some in the for sale sections or free sections.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #4 of 17 Old 01-04-2006, 08:32 AM Thread Starter
Big_Black_YJ
so the T-5 it has is probably no better than my puegeot, buuttttt
the dana 300 is worthy of a swap?
i was afraid to say it because i know it's blasphmeny, but what i REALLY want is to do a CJ nose-conversion, and i know i can get the truck pretty cheap. I was just wondering what else is worth taking off of the Jeep.
but if it's worth re-building the CJ i definetly won't take her apart...
Swamp Donkey 4x4
1994 Saab Aero
post #5 of 17 Old 01-04-2006, 10:37 AM
Blthomas
Blthomas's Avatar
1979 CJ7
I was looking at the link posted. I read that the 79' has a quadratrac t-case? I was under the thinkng that the 79's had the Dana20.
Anybody sure that chart is 100% correct?
I'd like to be sure of what I have. I need to crawl under her again, but it's hard to tell what's what with the amount of grime I'm seeing.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #6 of 17 Old 01-04-2006, 10:47 AM
certifiablejeep
Bicentennial Nickel
1976 CJ5
I think the info needs some updating because it says the same thing for 76 and I know I have a D20... and it was stock.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #7 of 17 Old 01-04-2006, 10:53 AM
John Strenk
1976 CJ5
The quadratech is used with an automatic tranny (GMTH400?) used at that time. THe Dana 20 was used with the manual trannies (T-18 T-150). Looks like they forgot to add the Dana 20 for those years.
post #8 of 17 Old 01-04-2006, 10:57 AM
Blthomas
Blthomas's Avatar
1979 CJ7
That's cool. I haven't done much to my Jeep like I had planned, but one of my upcoming projects is to rectify the rear driveshaft situation I have.
Not being a longtime Jeep guy most of my info is printed from this site, and what others have told me.
If you asked me to pick a Dana300 from a Dana20 from a Quadratrac in a lineup I'd be lost....
Thanks for the heads up John.
Blair
81' CJ8 bone stock
Blthomas is offline
post #9 of 17 Old 01-04-2006, 11:12 AM
John Strenk
1976 CJ5
Actually, just look at the oil pan. The Dana 20 has a deeper oil pan than the Dana 300 and the Quadratec has the front and rear yokes on the same end.
post #10 of 17 Old 01-04-2006, 11:44 AM
Sprkplug
1978 CJ7
Quadra Trac was used with the automatic in years 76 through 79.
John is also correct with the Quadra Trac case. Both front and rear axles have passenger drop differentials.
John, did you get your 1 piece alxes in?
Sparkplug
1978 Jeep CJ 7 258 6cyl Quadra-Trac with T400. Custom 3" body lift. Flatfendered. Custom bumpers. Full 6 point roll cage. 36" IROK's. 2 1/2 suspenion lift and 1/2 shackle lift. GM HEI, Superior 1-piece axles, 4.88 gears, Weber carb. Locked front and rear. Best of all, fours sons who LOVE TO RIDE!
Sprkplug is offline
post #11 of 17 Old 01-04-2006, 12:13 PM
dawgates
1980 CJ7
What years is the CJ in the junkyard? If it's 82-86 it has the wide trac axles.
I would keep the YJ tub (it's galvinized) and swap out everything else. The older Dana 30 front and AMC 20 rear, are a lot strong then the axles you have now. FYI the Dana 300 transfer case started in 1980 and went until 86' 79 and older had the Dana 20 unless it was a auto trans.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #12 of 17 Old 01-04-2006, 12:14 PM
John Strenk
1976 CJ5
Originally Posted by Sprkplug
...John, did you get your 1 piece alxes in?
"You want it when?"
I was going to do that first week of Chrismas vacation but the wife had other plans.
Basically just waiting to bolt them in some day I have a couple of hours to spare.
post #13 of 17 Old 01-04-2006, 01:21 PM
Sprkplug
1978 CJ7
Originally Posted by John Strenk
"You want it when?"
I know I felt bad thinking I had a good part. Should have look better before offering Live and learn
Sparkplug
Sprkplug is offline
post #14 of 17 Old 01-04-2006, 01:50 PM Thread Starter
Big_Black_YJ
i think it's an 82-86
they had two, one was totaled head-on and i snagged the hard-top from it for $50, and this one sits complete in the back of the year...it's got the paddle style doors on it....and if i recal....the 81 and older Jeeps had a different handle, right?
i thought the amc 20 was weaker than the dana 35 because it's got two peice axles and the axles tubes aren't really held onto the pumpkin? Myth, or just wrong information?
Say if i trussed it and got those one-peice axles...what size tire could i run up on this puppy?
thanks for all the help
EDIT: i know it's a manual, and it's a 6 cylinder, but i don't know if it's a four or a five-speed?...were all 258's 5 speed T-5's?
Swamp Donkey 4x4
1994 Saab Aero
post #15 of 17 Old 01-04-2006, 02:24 PM
gigihurt
gigihurt's Avatar
i thought the amc 20 was weaker than the dana 35 because it's got two peice axles and the axles tubes aren't really held onto the pumpkin? Myth, or just wrong information?thanks for all the help
An amc 20 is plenty strong with one peice axles and welded tubes,truss etc. I ran 33 swampers to hell and back and lincoln locked the thing and never even spun the factory hubs. They are a 29 spline ,A 44 is only 30 spline I beleive. The transfer case will need to be flipped if you are not going to change your front end. As your drop is on the drivers side.
Yes all the 258s with a five speed were using the t5s. Some of them had a t176if I am not mistaken.
83 cj7 all stock except lift and tires and all the drive train.
gigihurt is offline
68 CJ-5 Drivetrain Tri_X_Troll Jeep CJ Forum 23 07-27-2007 01:25 PM
CJ7 drivetrain parts into a CJ5 Scuter83 Jeep CJ Forum 5 02-05-2007 04:06 PM
I need drivetrain CSI DrNewland Jeep CJ Forum 3 08-14-2006 06:14 PM
drivetrain luck Jeep CJ Forum 2 03-11-2005 06:23 AM
Drivetrain Jeepdawg Jeep CJ Forum 3 11-25-2003 07:35 PM
