Cj-7 doors revisited-hard doors the answer? - JeepForum.com
post #1 of 3 Old 11-12-2007, 05:53 AM Thread Starter
newjeepowner
I've posted a few times here since I bought my first jeep and the help here has been outstanding. I currently have half doors on my '79 cj7 and found I can't get uppers to fit the corner of my hard top correctly (which I now understand came off a yj).
So it seems the best thing to do for the winter would now be to get a set of old full steel doors from a cj and go back to half doors in the summer. It looks like I just disconnect a strap and the pull off the door over the pins. I've read that I might need to change the striker (it looks like I currently have a simple bolt configuration screwed to the body so I cautiously assume these are easy to swap back and forth with the doors if needed).
The door issue is fast becoming a headache and I want to make sure I understand any other issues and resolve it fast (and economically).
Can someone validate the above and/or warn me of any other possible issues w/the doors and top or the strikers or anything else? I probably have to travel a bit to find some doors and can't afford to come home with something that doesn't work. Do I have to get cj doors?(what years fit?) would tj doors fit?(if so, what years?) Would these fit? http://cgi.ebay.com/ebaymotors/94-JE...spagenameZWDVW
Finally, I'm wondering if full softdoors would fit the hardtop correctly as I suspect this would be even cheaper. I just dont want to wear a snowmobile suit to use the jeep this winter
Also, would this fit a 79 cj-7? http://cgi.ebay.com/ebaymotors/94-JE...QQcmdZViewItem
Sorry for all the questions and droning on and most importantly..
Thanks!
newjeepowner is offline
post #2 of 3 Old 11-12-2007, 07:16 AM
CjinPA
CjinPA's Avatar
I am going to guess that you have a hardtop from a YJ not a TJ. You should be able to buy soft upper doors that will fit with the hardtop. Here is a link to some on the 4wd.com site.
http://www.4wd.com/productdetails.aspx?partID=7698
Full doors from CJ-7's and YJ's will fit your Jeep. The door strikers may need to be changed depending on what year doors you buy. 1981 and newer doors will have the striker pin style latch.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #3 of 3 Old 11-12-2007, 08:27 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
I just put my hardtop on yesterday (82 cj-7) and i have to swap my strikers. My hard doors/hard top have the little plates for the door latch to catch on. For my bestop supertop i had to install the pin strikers for the soft doors to latch on. After i installed my hard top i wanted to try and put my soft doors on with my hard top but where my soft doors come down off the back side radius its a straight shot down. On my hard doors/hard top there is an offset right below the window on the rear of the door that conforms to the offset in the hard top. This offset dose not allow me to run my bestop soft doors with a factory hard top.
So every year i need to swap top, doors, and strikers as a set so everything will match up.
hope that helps at all.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
Hard doors won't fit! aje3721 Jeep CJ Forum 6 10-10-2008 12:18 PM
want a hard top bad!! And doors Jeepdude84 Jeep CJ Forum 9 10-05-2008 03:44 PM
Two Piece Soft Doors VS. Lower hard doors with soft upper halves JeepScrambler Jeep CJ Forum 6 10-27-2005 07:29 AM
hard doors CJ7Rubicon Jeep CJ Forum 1 12-06-2004 08:22 PM
82 CJ7 Hard Top and doors damien0304 Jeep CJ Forum 0 02-05-2004 10:49 AM
