CJ-7 Dana 30 I.D. - JeepForum.com
post #1 of 8 Old 05-24-2009, 03:33 PM Thread Starter
Blue84JeepCJ7
Blue84JeepCJ7's Avatar
CJ-7 Dana 30 I.D.
I found the numbers on my Dana 30 front axle. Its 3:54 gears. Also stamped on the plate are the following numbers:
46-13
5363735
Can ya tell me what is what? I'm sure one is the date and the other maybe the part number?
84 CJ-7
Chevy 350, Mild Cam. (325hp)
Summit (600 CFM) Carb.
1987 TH700R4 "K" Case
32x11.5x15 Cooper ATs
3" Body Lift
Be-Cool Radiator
Black Magic 175 Cooling Fan
Blue84JeepCJ7 is offline
post #2 of 8 Old 05-24-2009, 03:38 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The 46-13 is the ratio.. it's the number of ring gear teeth and the number of pinion gear teeth... 46/13=3.538
Not sure what the other number is...
BESRK is offline
post #3 of 8 Old 05-24-2009, 03:39 PM Thread Starter
Blue84JeepCJ7
well shut my mouth, leanrt somethen new today!
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #4 of 8 Old 11-30-2011, 11:15 AM
LongueCarabine
Whoa! Something is not making sense on my 85 CJ. My rear AMC 20 has a code of DD, which corresponds to a 2.73 Trak Lok per the charts on Jeeptech.
My front Dana 30 lists the same codes as the poster above (3.54). The tag reads as follows:
5363735
3-54 46-13
What gives? I am sure that both axles have the same ratios ( I haven't noticed any problems along those lines). So what next? Do I need to tear down each diff and count teeth?
This came about because I am changing out my rear axle pinion seal.
LC
LongueCarabine is offline
post #5 of 8 Old 11-30-2011, 12:49 PM
CSP
That's what I would do if it were mine.
CSP is offline
post #6 of 8 Old 11-30-2011, 01:35 PM
WindKnot
1977 CJ7
Or at least count driveshaft rotations per wheel rotation. It won't be as accurate, but would be close, less trouble and cleaner. I'd only worry and explore more deeply if the front count didn't match the rear. It will give you a pretty good idea of what the ratio is. I doubt someone would go to the trouble of changing a 3:54 to a 3:71. I bet it would be more drastic than that.
The tag only tells you how it was built at the factory. Once it leaves... who knows? ESPECIALLY on a 30 some odd year old Jeep.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 8 Old 11-30-2011, 05:02 PM
Rick7
If the front and rear ratios were that far different, you would notice right away. At one time I bought a CJ5 and later discovered it had mismatched ratios front and rear. The first time I used 4wd was on ice waiting in line with cars to go up to Lake Tahoe on Hwy 50. I applied the throttle to move forward, and there was no forward movement at all,-- as soon as the wheels started turning at different speeds, the Jeep immediately slid sidewise off the side of the road. I did the remainder of the trip in 2wd.
Rick7 is offline
post #8 of 8 Old 11-30-2011, 06:37 PM
LongueCarabine
Thanks for the responses. I am probably going to open up both pumpkins anyway to make sure which I have, since I am going to re-power this thing hopefully soon. It's obvious that one of them changed, and I want to make sure I know what ratio I have. Since I am doing the pinion seal anyway, this is the perfect time.
LC
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Swapping Disc Brakes from 81 Dana 30 to 76 Dana 30 PortlandCJ76 Jeep CJ Forum 2 05-13-2007 04:11 PM
dana 44 spindles bolt to dana 30 nuckles? CJ7Laredo Jeep CJ Forum 2 09-26-2006 10:55 PM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
