CJ-7 - JeepForum.com
post #1 of 4 Old 04-28-2002, 08:24 PM Thread Starter
Nate_Brock
Post CJ-7
Hi I just bought an '83 CJ-7 with an automatic tranny and I was wondering how hard it would be to find/change to a manual. I'm new Jeeps so if anyone has any good sites for body parts I have some rust problems, thanks.
Nathan F. Brock
Nate_Brock is offline
post #2 of 4 Old 04-29-2002, 04:42 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
It's a lot of work, but can be done. You will need all of the stuff you think you need, plus linkages, new pedals, new holes on the firewall, wiring changes, new steering column, as well as new flywheel and the like.
best of luck
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 4 Old 04-29-2002, 06:49 AM
nvyblue_cj7
Post
All I know as far as converting to a manual tranny is that the transmission is available in catalogs, I know I've seen it in the Quadratec catalog running upwards of $1500.00. You could probably get the clutch pedal or something from a junkyard, but be prepared for an expensive operation.
In the Quadratec master catalog or website (www.quadratec.com)they sell floor pans, and pre-fab sheet metal for specific parts of the Jeep body. It's usually listed in the restoration category. Or, if you don't want to dish out the money, you could cut sheet metal to size for whatever you want to replace, and weld it from there.
Good Luck!
-Nick
1984 CJ7-31" BF Goodrich AT Tires, Auto, 258 ci, Pioneer sound, 2 barrel Weber carb, undergoing some body work and exhaust work sometime soon.
"pop the hood, POP THE HOOD!"
- a phrase commonly heard in my garage
nvyblue_cj7 is offline
post #4 of 4 Old 04-29-2002, 08:55 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
My '77 CJ-7 in my sig was originally an auto, and was converted to a Manual.
Check Ebay for parts, there is a guy near me right now selling a Clutch pedal assembly cheap. Also, don't buy a tranny out of a catalog, big waste of money, find one on here or on Ebay! Trannies are all over the place! You'll have to get a bellhousing, also easy to find. Front and rear driveshafts will have to be retubed or just get used/new ones, if the yoke/u-joint sizes are different. You'll have to obviously vut a hole in your tunnel, no big deal. Clutch linkage is available new, no problem there.
Seriously, look around on Ebay and in the catalogs, check <a href="http://www.4wd.com" target="_blank">www.4wd.com</a> and <a href="http://www.quaratec.com" target="_blank">www.quaratec.com</a> for new parts when you an't find good used ones.
It's not that big a deal to swap, really, just takes a little time for your modifications. As I said, many of your parts can be found reasonably cheap on here in Swap Section or on Ebay. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
