CJ-7, 4.2L. Ran Out of Gas and Now Won't Run?!?!... - Page 3 - JeepForum.com
post #31 of 34 Old 02-04-2013, 11:43 AM
Davis77Cj
1977 CJ7
did you check all of your vacuum lines for leaks? the timing? fuel pressure? or you could have a really weird ignition module.
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #32 of 34 Old 02-04-2013, 12:19 PM
86cj74.2L
86cj74.2L's Avatar
You did not answer my idle mixture screw question.
86cj74.2L is offline
post #33 of 34 Old 02-04-2013, 08:45 PM Thread Starter
dvzant
Ok, I think I have it now!!! I took the carb off again and tore it down just to be sure. I paid particular attention to the mixture screws, ran a wire through any hole I could fine and shot carb cleaner through everything. When I put it back on I opened the mixture screws out 5 turns from closed.
It may be a bit too much fuel now and I may have to dial it back but I'm just happy it's idling. I'll need to re-time it and then I'll fine tune the mixture screws.
Thanks for all of the advice, everyone was a big help! If nothing else, I know more about this BBD carb.
dvzant is offline
post #34 of 34 Old 02-11-2013, 11:06 PM Thread Starter
dvzant
Update: I got the Jeep dialed in and it passed smog!!
I described my headaches to my mechanic/smog tech and he described a trick that sometimes work for him in similar circumstances.
He said to rev the engine pretty high and close the choke flap until the engine is about to die. Open the flat while still giving it gas so it revs back up quickly. That will sometimes dislodge blockages.
I figure that everyone was able to give me a lot of advice... Maybe that bit of advice with help someone else out....
dvzant is offline
rough idle , sputtering
