CJ-5 won't start - complete novice - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ-5 won't start - complete novice
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-14-2014, 03:33 PM   #61
LumpyGrits
CK for fuel flow----
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 03:36 PM   #62
sabbyATL
1974 CJ5
Originally Posted by Mike Romain View Post
The jumper just gives power to the ignition, you still need to use the key to start it.. :-)
OK, do I just need to turn it to ON or do I need someone to crank it?
Because I did turn it to ON and the above description is what happened.
sabbyATL is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 03:36 PM   #63
LumpyGrits
Crank it.
LG
Unread 04-14-2014, 03:37 PM   #64
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Originally Posted by LumpyGrits View Post
Crank it.
LG
Yup
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 03:40 PM   #65
LumpyGrits
Mike-I've got a Doc's app. to go to(heart med's). Please help her out, will you.
Won't be back till eve.
LG
Unread 04-14-2014, 03:41 PM   #66
Mike Romain
LG
Ok I can keep checking in on my phone. Curiosity is up too.
Mike
Unread 04-14-2014, 03:50 PM   #67
Mike Romain
And if by some miracle it does start this way it won't shut off until you unhook the jumper wire!
Mike
Unread 04-14-2014, 03:59 PM   #68
sabbyATL
1974 CJ5
Ha! I went and had my husband crank it. No go.
I'm at Barrett's Performance in Atlanta getting a new ignition...just in case. Because they close soon.
Unread 04-14-2014, 04:05 PM   #69
Mike Romain
OK make sure you get that jumper off or it will cook the coil.
The solenoid isn't the issue.
Mike
Unread 04-14-2014, 04:26 PM   #70
sabbyATL
1974 CJ5
Yeah, the jumper was off as soon as it didn't work.
I got a new distributor and new wires because the old distributor had female heads and the new one has male.
Am I right in thinking I should just go ahead and replace the distributor?
Unread 04-14-2014, 04:43 PM   #71
sabbyATL
1974 CJ5
Chris at Battery's also recommended I get a coil and try that first. However, the coil isn't returnable while the distribute and writes
are.
So, do I go ahead and change out the coil first?
Unread 04-14-2014, 04:46 PM   #72
LumpyGrits
On the wife's phone so my spell'n will be worst......
Do you have a timing light and the specs needed to set ign. timing?
Why did you decide to replace the 'dizzy'? Did it test bad? Did you even have it tested?
Did you ever ck for fuel flow??
LG
Unread 04-14-2014, 04:48 PM   #73
LumpyGrits
are.
Chris is a salesman.........Remember that
LG
Unread 04-14-2014, 04:51 PM   #74
sabbyATL
1974 CJ5
LG
Sorry, I'm not getting alerts for every post...
Fuel flow is fine. I think. Based on:
Unread 04-14-2014, 04:52 PM   #75
sabbyATL
1974 CJ5
LG
He was recommended by a friend of mine who restores old cars. Said he'd be able to help.
I'm pretty cynical about sales guys. But I'm inclined to be positive about personal recommendations.
cj-5 , ignition , start , start problems
