CJ-5 won't start - complete novice - Page 7 - JeepForum.com
post #91 of 107 Old 04-14-2014, 05:49 PM Thread Starter
sabbyATL
1974 CJ5
Originally Posted by LumpyGrits View Post
THX-I have class2+, CHF.
Did you ever ck for fuel flow?
LG
I think my friend did yesterday but I'll check in a sec.
sabbyATL is offline
post #92 of 107 Old 04-14-2014, 05:52 PM Thread Starter
sabbyATL
1974 CJ5
Originally Posted by Matt1981CJ7 View Post
Replace the ICM.
So, not knowing what that looked like I googled it. I came across this thread.
I tested the coil the way they indicated in post #10. I disconnected all wires from it and here's what happened (also the top, just didn't photograph it):
sabbyATL is offline
post #93 of 107 Old 04-14-2014, 05:58 PM Thread Starter
sabbyATL
1974 CJ5
LG
Oh, well, I hope you're doing well.
sabbyATL is offline
post #94 of 107 Old 04-14-2014, 06:03 PM
LumpyGrits
Above the dirt-
IF/WHEN, you do change ICM or the dizzy. Disconnect the battery POS(+)cable, first.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #95 of 107 Old 04-14-2014, 06:05 PM
Mike Romain
You have 0 ohms between the + and - of the coil? That implies it got cooked from too much power.
Mike
Mike Romain is offline
post #96 of 107 Old 04-14-2014, 07:32 PM Thread Starter
sabbyATL
1974 CJ5
Yes. I'm thinking when I turned the starter when the engine was already running I caused a power surge that fried it...???
I've replaced it.
Started right up. No hesitation. No r-r-r-r.
Yay!!!!!!!!!!
Thank you so much, guys!
Yay yay yay yay yay!!!
sabbyATL is offline
post #97 of 107 Old 04-14-2014, 07:39 PM
LumpyGrits
Yup-Your reading shows the coil was 'dead'.
Glad it's run'n!
LG
post #98 of 107 Old 04-14-2014, 07:42 PM Thread Starter
sabbyATL
1974 CJ5
Now I'm taking my family for a ride!
sabbyATL is offline
post #99 of 107 Old 04-14-2014, 07:48 PM
LumpyGrits
I'd be very affraid..........
post #100 of 107 Old 04-14-2014, 07:56 PM Thread Starter
sabbyATL
1974 CJ5
Is that any way to treat a lady you've spent all day with?
sabbyATL is offline
post #101 of 107 Old 04-14-2014, 08:01 PM
LumpyGrits
It's what happens after dark, that counts.....
LG
post #102 of 107 Old 04-15-2014, 05:04 AM
Mike Romain
Congrats! It sure was a strange one. I wonder how many volts that starter put out when it got spun up by the flywheel. Every other time I have seen this, it blew the fuse link first, but then I didn't ever see an ignition fuse link on yours.
Mike
post #103 of 107 Old 04-15-2014, 05:12 AM Thread Starter
sabbyATL
1974 CJ5
Congrats! It sure was a strange one. I wonder how many volts that starter put out when it got spun up by the flywheel. Every other time I have seen the fuse link first, but then I didn't ever see an ignition fuse link on yours.
I'm very curious, too, as to the details of the power surge. I think I'm going to investigate.
I wonder...should I install a fuselink? I don't know what it looks like (will Google). But that's what guides are for, right? To stop a surge?
I'm glad we solved it relatively quickly. I mean, someone with more experience than I probably would've figured it out in an hour or so. I was doing the back and forth with you guys - following instruction, posting, waiting, repeat. But I'm glad we figured it out.
Now I can drive her. And my son asked if we can name her Josephine instead of Marge, so Josie it is.
Thanks, again!
sabbyATL is offline
post #104 of 107 Old 04-15-2014, 05:32 AM
Mike Romain
I play with microhydro (Water wheel)setups and a DC motor can work 2 ways. Put power to it and it spins. Spin it and it gives power out.
Some folks use record turntable motors (DC) and spin them with a water wheel to get a trickle charge for a battery pack to help charge them. They give a couple amps 24/7 which is good for a weekend use camp power.
A starter spun up real fast like that by a flywheel, likely put out a lot of power in a hurry. Well, enough to cook the insulation of the coils windings anyway.
Mike
post #105 of 107 Old 04-15-2014, 05:51 AM
bdatkins
1978 CJ5
Yay! That was almost like a choose your own adventure book "Turn to page 4 if you want to check your fuel flow. Turn to page 6 to check your spark." I'm glad you got it figured out. Enjoy your 5!
bdatkins is offline
cj-5 , ignition , start , start problems
