CJ-5 won't start - complete novice - Page 6 - JeepForum.com
post #76 of 107 Old 04-14-2014, 03:53 PM
Mike Romain
I am thinking it is the 7500 ignition box that cooked, not the coil or distributor.
Mike
Mike Romain is offline
post #77 of 107 Old 04-14-2014, 03:54 PM Thread Starter
sabbyATL
1974 CJ5
Originally Posted by LumpyGrits View Post
On the wife's phone so my spell'n will be worst......
Do you have a timing light and the specs needed to set ign. timing?
Why did you decide to replace the 'dizzy'? Did it test bad? Did you even have it tested?
Did you ever ck for fuel flow??
LG
Oh, when you say timing do you mean the order in which the cylinders fire, as stamped on the engine case?
sabbyATL is offline
post #78 of 107 Old 04-14-2014, 03:55 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm enjoying watching LG and Mike stumble over each other trying to help a Damsel in distress.
You two studs rock on.
Matt1981CJ7 is online now
post #79 of 107 Old 04-14-2014, 03:56 PM Thread Starter
sabbyATL
1974 CJ5
Can I get that anywhere? Like AutoZone?
I'd they another step in diagnosing this?
sabbyATL is offline
post #80 of 107 Old 04-14-2014, 04:01 PM
Mike Romain
I would next pull out a spark plug, ground it plugged in and crank the starter to see if you have spark.
I would also want to know what supplies the power to the 7500 box and would be checking out that circuits fuse.
Don't know who sells the box or how to test the pinouts on it. Maybe Google will give you a test procedure.
Mike
post #81 of 107 Old 04-14-2014, 04:04 PM Thread Starter
sabbyATL
1974 CJ5
We actually tried that yesterday. That friend I mentioned came over and he did that test. I probably shouldn't mentioned it sooner...note that I understand where you're leading me. Anyway, no spark when we did that.
sabbyATL is offline
post #82 of 107 Old 04-14-2014, 04:09 PM
Matt1981CJ7
1981 CJ7
I gave you a link to the test procedure earlier, but perhaps you missed it.
Here it is again. Read the first two posts and follow the directions. You'll figure it out.
http://www.jeepforum.com/forum/f8/je...-help-1092376/
Matt
post #83 of 107 Old 04-14-2014, 04:12 PM
LumpyGrits
Ign timing as when the spark fires inside the engine. You twist the dizzy at all-It changes real fast.
That pic of the fuel filter sayz nut'n. Doesn't mean the fuel is move'n at all.
Gotta go for the MRI now.....Dang stuff I had to drink, tastes BAD.......
Later,
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #84 of 107 Old 04-14-2014, 04:15 PM Thread Starter
sabbyATL
1974 CJ5
Later,
LG
Oh, I hope you're going to be okay!
sabbyATL is offline
post #85 of 107 Old 04-14-2014, 04:17 PM Thread Starter
sabbyATL
1974 CJ5
Hi Matt,
Sorry, I did see it. But I was getting pretty fast instruction from you guys and from my friend via text (you both pretty much had me do the same stuff...which was reassuring) that I didn't get a chance to examine it and then forgot about it.
sabbyATL is offline
post #86 of 107 Old 04-14-2014, 04:27 PM Thread Starter
sabbyATL
1974 CJ5
So, after a bit of googling, here's what the 7500 box is (you probably already know, but I didn't):
sabbyATL is offline
post #87 of 107 Old 04-14-2014, 04:57 PM Thread Starter
sabbyATL
1974 CJ5
Ok, so I read through that thread Matt recommended.
I think we've already done everything there:
1. We know the solenoid isn't the problem
2. I tested the other side of the coil (though I'm not sure if this is the right way to test it) - black probe to coil (-) and red to battery (+). Get 11.5mV.
sabbyATL is offline
post #88 of 107 Old 04-14-2014, 04:58 PM Thread Starter
sabbyATL
1974 CJ5
But no spark using an old spark plug plugged into the distributor wire.
sabbyATL is offline
post #89 of 107 Old 04-14-2014, 05:01 PM
Matt1981CJ7
1981 CJ7
Replace the ICM.
post #90 of 107 Old 04-14-2014, 05:27 PM
LumpyGrits
THX-I have class2+, CHF.
LG
cj-5 , ignition , start , start problems
