CJ-5 won't start - complete novice - Page 5 - JeepForum.com
post #61 of 107 Old 04-14-2014, 02:33 PM
LumpyGrits
CK for fuel flow----
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #62 of 107 Old 04-14-2014, 02:36 PM Thread Starter
sabbyATL
1974 CJ5
Originally Posted by Mike Romain View Post
The jumper just gives power to the ignition, you still need to use the key to start it.. :-)
OK, do I just need to turn it to ON or do I need someone to crank it?
Because I did turn it to ON and the above description is what happened.
sabbyATL is offline
post #63 of 107 Old 04-14-2014, 02:36 PM
LumpyGrits
Crank it.
LG
post #64 of 107 Old 04-14-2014, 02:37 PM
Mike Romain
Originally Posted by LumpyGrits View Post
Crank it.
LG
Yup
Mike
Mike Romain is offline
post #65 of 107 Old 04-14-2014, 02:40 PM
LumpyGrits
Mike-I've got a Doc's app. to go to(heart med's). Please help her out, will you.
Won't be back till eve.
LG
post #66 of 107 Old 04-14-2014, 02:41 PM
Mike Romain
LG
Ok I can keep checking in on my phone. Curiosity is up too.
Mike
post #67 of 107 Old 04-14-2014, 02:50 PM
Mike Romain
And if by some miracle it does start this way it won't shut off until you unhook the jumper wire!
Mike
post #68 of 107 Old 04-14-2014, 02:59 PM Thread Starter
sabbyATL
1974 CJ5
Ha! I went and had my husband crank it. No go.
I'm at Barrett's Performance in Atlanta getting a new ignition...just in case. Because they close soon.
sabbyATL is offline
post #69 of 107 Old 04-14-2014, 03:05 PM
Mike Romain
OK make sure you get that jumper off or it will cook the coil.
The solenoid isn't the issue.
Mike
post #70 of 107 Old 04-14-2014, 03:26 PM Thread Starter
sabbyATL
1974 CJ5
Yeah, the jumper was off as soon as it didn't work.
I got a new distributor and new wires because the old distributor had female heads and the new one has male.
Am I right in thinking I should just go ahead and replace the distributor?
sabbyATL is offline
post #71 of 107 Old 04-14-2014, 03:43 PM Thread Starter
sabbyATL
1974 CJ5
Chris at Battery's also recommended I get a coil and try that first. However, the coil isn't returnable while the distribute and writes
are.
So, do I go ahead and change out the coil first?
sabbyATL is offline
post #72 of 107 Old 04-14-2014, 03:46 PM
LumpyGrits
On the wife's phone so my spell'n will be worst......
Do you have a timing light and the specs needed to set ign. timing?
Why did you decide to replace the 'dizzy'? Did it test bad? Did you even have it tested?
Did you ever ck for fuel flow??
LG
post #73 of 107 Old 04-14-2014, 03:48 PM
LumpyGrits
are.
Chris is a salesman.........Remember that
LG
post #74 of 107 Old 04-14-2014, 03:51 PM Thread Starter
sabbyATL
1974 CJ5
LG
Sorry, I'm not getting alerts for every post...
Fuel flow is fine. I think. Based on:
sabbyATL is offline
post #75 of 107 Old 04-14-2014, 03:52 PM Thread Starter
sabbyATL
1974 CJ5
LG
He was recommended by a friend of mine who restores old cars. Said he'd be able to help.
I'm pretty cynical about sales guys. But I'm inclined to be positive about personal recommendations.
sabbyATL is offline
cj-5 , ignition , start , start problems
