CJ-5 Rebuild - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ-5 Rebuild
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread Yesterday, 11:10 PM   #1
FrictionPro
CJ-5 Rebuild
The jeep has been inside for about 22 years and in neutral with the drive shaft removed. Tried to move shifter and it will not move at all. The clutch seems to be doing something when it is mashed but can't be sure. What do I need to do to free up the shifter.
FrictionPro is offline   Reply With Quote
Unread Today, 01:19 AM   #2
BagusJeep
BagusJeep's Avatar
1981 CJ7
If you filled out your Profile you would get more definitive answers, still wrong but definitively wrong.
What state is the rig in and do you have it in bits or is it whole?
If the vehicle is complete and untouched the clutch will probably not disengage. It is stuck from 20 years of inuse. If it runs and can move you can free up the clutch with some brute force. I would put it in low range and start it in gear, then when it is running forwards push the clutch, accelerator and handbrake (footbrake is aksing a bit much) togather. The engine force will sometimes cause the clutch to lose the grip and start spinning.
What you can do to the gearbox depends on whether it is in the vehicle and which vehicle it is. I woudl at least try to take off the shifter boots and panel around teh gearstick ad remove the top of the box. This will allow you to see if it is rusted solid or just seized up from years of sitting there. If the latter you could try some very light oil to penetrate the gummed parts and if it frees up change it.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now   Reply With Quote
