CJ 5 No Power to anything! - JeepForum.com
post #1 of 3 Old 02-11-2017, 01:41 PM Thread Starter
thebeastcj5
Cj CJ 5 No Power to anything!
I have a 1979 CJ 5 with the 4.2L Inline 6. When i turn the key I get nothing. I checked the battery it is still good. Alternator has been replaced and checked again, still good. The lights will not even turn on. It is like I removed the battery. Cables on the battery are new also. I can run a jumper to the power line on the distributor from the battery and bypass the solenoid and it will start. When I do this though I can't turn it off without pulling the wire from the battery. I also have installed a new ignition switch still nothing. Any thoughts?
thebeastcj5 is offline
post #2 of 3 Old 02-11-2017, 02:05 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sounds like you may have crossed up a wire on the starter solenoid, or it's bad.
Matt
Matt1981CJ7 is offline
post #3 of 3 Old 02-15-2017, 03:13 PM Thread Starter
thebeastcj5
I have been thinking about that. I know it is wired correctly because it has been running great for a year and then suddenly I went to start it and nothing. Then a few hours later it would start Then it would do it all over again but it hasn't started for few months using the ignition. Would a bad starter solenoid kill the light also?
no power , wire harness , won't crank , won't start
