CJ 4.2L Starting problem - Page 2 - JeepForum.com
post #16 of 26 Old 07-06-2010, 06:13 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by VACJ7 View Post
It is only there to eliminate noise in your radio from the ignition.
Ditto that. I went through the same question. My capacitor crapped out (the wire broke off) and I haven't gone back to replace it yet because I haven't had time to install a radio.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #17 of 26 Old 07-06-2010, 06:29 PM
crzdmnky
1978 CJ5
Flux core capacitor?
crzdmnky is offline
post #18 of 26 Old 07-06-2010, 06:32 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Yeah, that's it. It broke off when I was changing the brake light fluid.
Ken4444 is offline
post #19 of 26 Old 07-06-2010, 06:37 PM
crzdmnky
1978 CJ5
Man, It doesnt beat having to replace muffler bearings on this CJ. Them things are tough to get to, and on top of that there is a special hard to get tool you have to rent from Autozone to take it out. Major Suckage.
crzdmnky is offline
post #20 of 26 Old 07-07-2010, 11:22 PM Thread Starter
planb722
so is a nutter an option to fix a no spark problem??
planb722 is offline
post #21 of 26 Old 07-08-2010, 04:43 AM
tigercreek
It's an option IF your ECM is causing the problem. Doing the Nutter Bypass simply removes the ECM from the ignition loop. From that point on everything ignition related will be controlled manually.
Again, I suggest you find what is causing the no fire situation before making yet another change.
No matter where you go, there you are.
tigercreek is offline
post #22 of 26 Old 07-08-2010, 06:02 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Agreed. You might take the time to read the following post. It detals the troubleshooting steps I went through to narrow down my problem with the help of JeepHammer. It will help you troubleshoot a number of areas that could cause your problem:
http://www.jeepforum.com/forum/f8/25...spark-1045702/
You could perform the Nutter Bypass first, but be aware that to perform the complete procedure you'll need a timing light and you'll be working on the carburetor's stepper motor, so it's not as easy as just running a couple of wires.
Ken4444 is offline
post #23 of 26 Old 07-08-2010, 09:22 AM Thread Starter
planb722
thanks for the thread...I'll follow it through and let you know of the results...
planb722 is offline
post #24 of 26 Old 07-19-2010, 07:17 PM Thread Starter
planb722
still no spark...
I followed the thread...tested the pick-up (at 450 ohms)...I added a ground wire as recommended to the module...I tested the red wire at the coil, it shows dim with ignition on and gets brighter when cranked...I tested the green wire, it had a solid light even when cranking...assumed(I know) module was still bad, replaced it and had same results...
What next????
planb722 is offline
post #25 of 26 Old 07-19-2010, 08:16 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
You could try the wiring portion of the Nutter Bypass to bypass the ECM. That would eliminate one big potential variable. If that fixes it, then you either get a new ECM and back out the wiring changes. Or continue with the other steps in the Nutter (adjust timing, set carb metering pins, etc)
Ken4444 is offline
post #26 of 26 Old 07-22-2010, 07:52 AM Thread Starter
planb722
I did the wiring portion of the nutter and now have spark at the coil and plugs but it still wouldn't start. Is that because I need to finish the rest of the bypass (metering pins and hoses)? How much more wiring can I eliminate now with the bypass?
planb722 is offline
4.2 , coil , ignition module , ignition problem , start problems
Starting problem jeepjamboree Jeep CJ Forum 3 05-07-2011 11:29 AM
Starting problem Chasebo Jeep CJ Forum 7 08-17-2009 02:54 PM
85 CJ Starting Problem bmg97 Jeep CJ Forum 5 05-09-2006 03:46 PM
Starting problem nsamaster0414 Jeep CJ Forum 11 08-23-2004 01:03 AM
Starting Problem joconnor66 Jeep CJ Forum 0 08-11-2003 09:09 AM
