CJ 4.2L Starting problem - JeepForum.com
post #1 of 26 Old 07-05-2010, 02:48 PM Thread Starter
planb722
I have an 86 CJ7 with a 4.2L engine. Went to start it a few days ago and it fired and died immediately it did it 2 more times and now no fire at all. I figured ti was the ign control module so i had it tested and it checks okay. I replaced the ign coil pick up, the coil, cap, and rotor. Still no fire...had a friend convince me it was the module even though it tested okay. Replaced the module still no fire...i've checked the resistance on the coil and pickup. They test within spec. I've got the correct voltage at the coil as well. Even went so far as to run a jumper direct from the battery to the coil. I've checked to make sure there is electricity to the module and made sure it was grounded. I'm at a loss so any help would be much appreciated.
planb722 is offline
post #2 of 26 Old 07-05-2010, 02:55 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Do you have spark ?
Do you have fuel ?
LT1CJ7 is offline
post #3 of 26 Old 07-05-2010, 04:00 PM Thread Starter
planb722
I have fuel but no spark
planb722 is offline
post #4 of 26 Old 07-05-2010, 04:36 PM
tigercreek
When you say "no fire" - do you mean it won't start or that you don't have any spark?
If you pull a plug, ground it and crank does it spark?
Have you check the pickup in the distributor? They can go out and give you a no spark situation.
Just work your way forward or backward in the ignition system to find where you are losing the voltage.
No matter where you go, there you are.
tigercreek is online now
post #5 of 26 Old 07-05-2010, 05:29 PM Thread Starter
planb722
no spark...i replaced the pick up coil already
planb722 is offline
post #6 of 26 Old 07-05-2010, 10:46 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Bad ECM
LT1CJ7 is offline
post #7 of 26 Old 07-06-2010, 03:52 AM
Lordwrench
1978 CJ7
"If you pull a plug, ground it and crank does it spark?"
What tiger said,you never answered.
Lordwrench is offline
post #8 of 26 Old 07-06-2010, 04:38 AM
tigercreek
If all of your components are testing good you may want to be looking at the connections and/or wiring between them.
Again, start by finding where the voltage falls off with everything hooked up.
LT1CJ7 suggested the ECM. DO you still have it hooked up? Have there been any ignition modifications.
There are a lot of people here that can help you and the more specific information you provide the faster a solution can come.
post #9 of 26 Old 07-06-2010, 07:58 AM Thread Starter
planb722
no spark when the i pulled a plug and grounded it...yes the ecm is still hooked up and no i haven't made any ign mods...is it possible to do away with the ecm? I have power going in to the module but when I test the wires going to the pick up there isn't anything. The only part i haven't replaced is the capacitor could that be the problem?
planb722 is offline
post #10 of 26 Old 07-06-2010, 08:29 AM
tigercreek
You can eliminate the ECM. Do a search for "Nutter Bypass"
Probably should solve your problem here first.
How have you "tested" the pickup stator in the distributor?
The stock pickup in the distributor can be tested using an ohm meter.
Orange and purple should show between 400-800 ohms with 600 being nicest between ideal.
Neither of those wires should show continuity to ground.
Replace the stator if anything here is off.
post #11 of 26 Old 07-06-2010, 04:51 PM Thread Starter
planb722
i'll retest the pickup and let you know... The only component that i haven't replaced was the capacitor... if it's bad could that be the cause of no spark?
planb722 is offline
post #12 of 26 Old 07-06-2010, 05:20 PM
crzdmnky
1978 CJ5
NUTTER NUTTER NUTTER! Search for John Nutters bypass in the search button...
crzdmnky is offline
post #13 of 26 Old 07-06-2010, 05:37 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Agreed on the Nutter. It's easy to do if you take your time and understand what you're doing.
Here's the main Nutter how-to
If you need to clean up your vaccum lines after the Nutter, here's the Post Nutter cleanup thread (unofficial)
Here are the before/after diagrams that show the wiring change you make as part of the Bypass. These are simple but explain the wiring change 100 times better than the how-to, IMO:
I had the same problem (only a single spark, and engine wouldn't start). After some troubleshooting and replacing the usual culprits (coil, ignition module), it still wouldn't start. I was going to do the Nutter anyhow and ultimately that fixed my problem.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #14 of 26 Old 07-06-2010, 05:45 PM
crzdmnky
1978 CJ5
Where does the red wire split off to coming from the coil? Just curious
crzdmnky is offline
post #15 of 26 Old 07-06-2010, 06:11 PM
VACJ7
VACJ7's Avatar
It is only there to eliminate noise in your radio from the ignition.
VACJ7 is offline
4.2 , coil , ignition module , ignition problem , start problems
Starting problem jeepjamboree Jeep CJ Forum 3 05-07-2011 11:29 AM
Starting problem Chasebo Jeep CJ Forum 7 08-17-2009 02:54 PM
85 CJ Starting Problem bmg97 Jeep CJ Forum 5 05-09-2006 03:46 PM
Starting problem nsamaster0414 Jeep CJ Forum 11 08-23-2004 01:03 AM
Starting Problem joconnor66 Jeep CJ Forum 0 08-11-2003 09:09 AM
