My father in law had me post a question for the cj guys.
4.2 with weber carb. Jeep starts but runs on 3 cylinders. There is spark on the 3 wires. Intake is clear. Compression was high,140 in each of the 3 cylinders. Were talking the back 3. Anyone else have this issue? I can answer questions
Of course. New distributor as well. Plugs are the correct gap. Spark was tested with a spark tester on every wire. Timing was verified also.
Valves are opening and closing. Carb has the correct spacers.
I don't think a dual plane manifold would make a difference on why the back 3 cylinders are lacking fuel. If spark is there and the timing order is correct, look towards the carb and how it's set up. Are the plugs even wet?
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
